Best N/A b16a setup?
Old Feb 17, 2003 | 10:51 AM
silverCRXTC's Avatar
Default Best N/A b16a setup?
After researching im still a bit stuck on what (or who to use) for my na b16a build up, im not a racer and this car is a daily driver, any advise on what or what not to do? Oh yeah its a first gen so i know my vavle springs are crappy and i need to upgrade the valve train, should i just do springs or valves too?
Old Feb 17, 2003 | 11:04 AM
Unsung's Avatar
Default Re: Best N/A b16a setup? (silverCRXTC)
street driven-
skunk2 valves/springs/retainers/stage1 cams for the head.
skunk2 ecu program
gsr bottom end- 11.5:1 pistons, eagle rods.
and after about $5000, you'll be ready!
Old Feb 17, 2003 | 11:10 AM
lazy bum shaughn's Avatar
Default Re: Best N/A b16a setup? (JDM B-Series)
street driven-
skunk2 ecu program
I doubt all that will cost $5000.
Anyway I'd get stage II cams and tuning.
i dont think i can run the skunk program in my pw0 (CR-X), how about the stage II cams, i mean if im upgrading the v-train why not go up a notch, or are they really not nessesary, and what do u guys think about portflow springs, ?
Old Feb 17, 2003 | 11:15 AM
simple4012's Avatar
New User
jun 3's cams, and valvetrain
CTR pistons (unless you wanna go aftermarket)
eagle rods
Hondata
Mill the head (if you use CTR pistons)
Jun flywheel
good clutch of ya choice
good short geared tranny
stay away from chipped ecu's they arent good
Old Feb 17, 2003 | 12:11 PM
joe_bocc's Avatar
Default Re: Best N/A b16a setup? (simple4012)
i believe that too. Hondatas can be customized for your car.
Old Feb 17, 2003 | 12:20 PM
eg6ajk's Avatar
not to hijack the thread but...
what is hondata ecu? a non-chipped ecu. its nothing more then a stock program which allows custom fuel/ignition/ maps as well as vtec/rev limit points.
chipped ecu has advantages and disadvantages when compared to hondata (which also isn't perfect)
there are few good programs that are avalible and which will make same power as Hondata (or close to) with excellent fuel economy and driveability.
Old Feb 17, 2003 | 12:54 PM
976's Avatar
976
New User
Default Re: Best N/A b16a setup? (eg6ajk)
Port and polished b18c1 head, 189whp. Pretty good cheap setup.
Another I've only heard of, not seen a dyno; of b18c1 bottom end. They said it showed great numbers.
I'm going CTR cams, jdm itr 4-1 header, itr tb, and itr intake manifold...
CivicSH
Mar 8, 2008 06:19 PM
Boosted_Coupe
Feb 23, 2008 10:18 AM
Speed_1
Aug 3, 2006 01:13 PM
jDMJeRk
Feb 3, 2004 12:14 AM
QWKPHKR
Nov 27, 2002 05:36 PM
