B16 Turbo Setup
Old Mar 23, 2005 | 02:12 PM
91Notch5.0's Avatar
Default B16 Turbo Setup
Well I am about to start building my B16 CRX....I'm first going to get a full Skunk2 valvetrain, then pistons and rods...Then onto the turbo setup...I want a good setup but I also want it be on the cheap side...I know they don't go together but you know what I mean....I only want to reach 250whp..so any good ideas on setups..engine manegment and all that Thanks
Old Mar 23, 2005 | 05:13 PM
PrettyLude's Avatar
you don't even need to build anything for the 250whp power level, just get a good tune on it
Old Mar 23, 2005 | 05:23 PM
LSVtechnologytur...'s Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you don't even need to build anything for the 250whp power level, just get a good tune on it</TD></TR></TABLE>
Old Mar 23, 2005 | 05:43 PM
91Notch5.0's Avatar
Default Re: (vtec'n)
exclude the pistons and rods....wasn't thinking right...I do want to upgrade the valvetrain cuz I have heard bad things about the stock 1st gen valvetrain....any good setups?
Old Mar 23, 2005 | 05:47 PM
BlueShadow's Avatar
yup, you can leave the valvetrain alone if you're only shooting for 250 HP.
To keep costs down you could look into these for your setup:
$40 DSM 450's
$10-$15 resistor box (if you your CRX doesn't have it already)
$89 Walbro 255lph intank fuel pump
FREE!!! Uberdata or Crome (obd 1) or Turboedit if you stick to OBD 0
$70-$110 ECU chipping suppleis and burner
$200-$300? Johnnyracecar intercooler
$200-$300 manifold
$400-$600 turbo (I would suggest a T3/T4
$300 downpipe and dumptube piping
$200 intercooler piping
$30-$50 1G DSM BOV
$80 silicone couplers and clamps
$20 vacuum lines
$100 oil feed/drain kit (contact Flamenco-T on H-T)
$200? to get somebody to weld up your IC, DP, and DT
$80 Hawker Odyssey PC680 sealed battery (since you have a CRX your battery is gonna have to go to the trunk)
$20-$40 misc brackets and bolts to mount battery to trunk floor
$100 power distribution block, 100A fuses, 100A fuse holder, 2GA wire, 4GA wire, misc
$??? might have to hack front crossmember to make room for downpipe, or get aftermarket crossmember (ie Full-Race, Lcon, spankjelly)
$40 may need to get EG halfsized radiator, (used OEM EG = $40-$80)
That's all I can think of...there is a lot more, probably about $500 for misc stuff I forgot to list.
Old Mar 23, 2005 | 05:49 PM
BlueShadow's Avatar
Default Re: (DSM2GNT95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSM2GNT95 &raquo;</TD></TR><TR><TD CLASS="quote">exclude the pistons and rods....wasn't thinking right...I do want to upgrade the valvetrain cuz I have heard bad things about the stock 1st gen valvetrain....any good setups?</TD></TR></TABLE>
If you dont wanna use the 1G valvetrain you could find a used set of GSR or ITR valvesprings from a reputable member. I haven't heard anything bad about 1G B16 valvetrains though. What specifically is it that you heard is bad about them?
Old Mar 23, 2005 | 06:18 PM
91Notch5.0's Avatar
Default Re: (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
If you dont wanna use the 1G valvetrain you could find a used set of GSR or ITR valvesprings from a reputable member. I haven't heard anything bad about 1G B16 valvetrains though. What specifically is it that you heard is bad about them?</TD></TR></TABLE>I know were a complete GSR valvetrain is for pretty cheap.....I just didnt know if it was worth it or not.....I just heard that they dont like the higher rpm's or bigger cams...I don't know maybe its just me
Old Mar 23, 2005 | 06:25 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSM2GNT95 &raquo;</TD></TR><TR><TD CLASS="quote">I know were a complete GSR valvetrain is for pretty cheap.....I just didnt know if it was worth it or not.....I just heard that they dont like the higher rpm's or bigger cams...I don't know maybe its just me</TD></TR></TABLE>
If you think you might go with ITR cams in the future you should just wait for some ITR valvesprings or maybe just get the Skunk2 valvesprings. but there are a few sponsors on H-T that might be able to give you a better price on a valvespring set.
If you'e gonna stick with B16 cams then you can stick to the B16 valvesprings. But if you upgrade cams then you'll want to upgrade the valvesprings along with them.
Old Mar 23, 2005 | 06:58 PM
Benjithx's Avatar
https://honda-tech.com/zerothread?id=1166909
lucky day, this turbo setup is perfect and not to spendy. spools super fast
2gen hatch
Jun 15, 2008 09:34 PM
SilverWarrior
Mar 31, 2008 11:39 PM
tigueremalo
10
Nov 22, 2007 11:43 PM
00garrettsi
Aug 12, 2007 01:45 PM
KrenzyRyan
10
Feb 21, 2006 06:18 AM
