uberdata and afc?
Old Mar 22, 2005 | 02:22 PM
silvercivic_ex-t's Avatar
Default uberdata and afc?
i had an afc hooked up to my car with a pair of 440rc. a month later a converted to uberdata and i still have the afc in the car hooked up because i like to see the real time rpm and real time boost. my question is, is uberdata running right even though i still have the afc hooked up? i don't know if i should solder the map senser wire together because i still have it hooked up through the afc and i'm not sure if i'm getting the right timming and fuel maps because of this? please help!!
Old Mar 22, 2005 | 02:23 PM
93turbo16's Avatar
Default Re: uberdata and afc? (silvercivic_ex-t)
as long as the AFC is at zero there should be no problem. I still have one in my car.
Old Mar 22, 2005 | 02:24 PM
so i shouldn't have a problem with the map sensor wire still be split up at the afc?
Old Mar 22, 2005 | 02:25 PM
93turbo16's Avatar
no, as long as it is not doing anything to the voltage it is fine.
Old Mar 22, 2005 | 02:27 PM
Default Re: (93turbo16)
and i can still use the afc to tweak around with fuel setting too?
Old Mar 22, 2005 | 02:28 PM
93turbo16's Avatar
no, that is why you have uberdata, that is defeating the pupose don't you think?
(you can if you wanted to)
Old Mar 22, 2005 | 02:29 PM
ok thanks for your help?
anyone else have any opinions on this?
Old Mar 22, 2005 | 02:33 PM
so you never spliced back you map sensor wire?
Old Mar 22, 2005 | 02:35 PM
93turbo16's Avatar
nope I never did. But you could if you wanted I guess.
Old Mar 22, 2005 | 04:26 PM
bump
Old Mar 22, 2005 | 05:10 PM
bump
Old Mar 22, 2005 | 05:41 PM
adseguy's Avatar
what other opinion do you want....93turbo16 answered all your questions......just turn your AFC down to change none of the timing or fuel values and use Uberdata...hell you really don't need your AFC as Uberdata can do all that and then some. but like he said you can keep it there just disable everything
Old Mar 23, 2005 | 01:29 PM
Default Re: uberdata and afc? (adseguy)
thanks
Old Mar 23, 2005 | 02:20 PM
specv5150's Avatar
how are you using your AFC as a boost gauge.........the pressure reading??
Old Mar 23, 2005 | 07:31 PM
Default Re: uberdata and afc? (specv5150)
yeah, it reads boost in bar!
abmerop18
Jan 19, 2005 07:08 AM
beepy
Nov 2, 2004 07:52 AM
XSNRGS-R
Jun 2, 2004 10:17 AM
SOFLSOL
Sep 4, 2003 09:18 AM
dwilson
Jun 5, 2002 04:49 PM
