b16 turbo
300WHP is the max you would wanna take the b16. thats going to its limit on the internals.. With a good tuner its very possible. Im doing a setup right now and looking for 280-300whp as well on my b16 when im done putting it together, but im goin with a bigger turbo becuase i do plan on building the motor. I will be posting pics of the setup as it comes along very shortly
Personally for your goal I would just use a stock intake and tb.Either 550 or 750 injectors would be fine.I would get the 750's as they are just a few bucks more and give you a little more room for power.Start right out with a forged piston.The stock rods are ok,but at this point a set of Eagles would also be a good idea.Save the money on the aftermarket flywheel,the stocker is fine.It's pretty easy to hit 300hp with a b16.A 38mm wastegate will be fine.
id say go with RC 740cc injectors as thats the biggest you can go WITH OUT a resistor box
But i agree dont waste your money on a intake manifold or flywheel you can make that goal with out those parts but just make sure you have a good clutch up to the job and a good tune
