which of these turbo should i use??
i bought 2 turbos and i don't know which one is best for my car. the car is a '99 SiR.
Turbo A - the seller said it's a T28 but i think(not sure) it's a bored out T25.
Turbo B - the seller said it's a T3
difference between turbos are:
- turbo A has a larger compressor blade as well as inlet.
- turbo B has a noticeably larger turbine housing as well as turbine blade compare to turbo A
is it possible to swap the parts so i'll have the best of both worlds??
which one should i choose????
lastly, where do guys get your coolant source for your turbo?
thanks.
thanks.
big strong guy
Re: which of these turbo should i use?? (_Endless_)
depends what your looking for? the t28 is great turbo for instant lower boost, and the t3 is great for more upper mid, high end power!! i like the t28!! good luck, eric
Re: which of these turbo should i use?? (mplex2000)
yup it's a b16. could you please tell me why is T3 better than a T28? how can i tell if it's really a T3? how bout T28/T25? i'm kinda new to turbocharging. thanks.
