Vovlo turbo
Old Apr 15, 2011 | 03:16 PM
lilrobie69's Avatar
Default Vovlo turbo
Ok lookin in the bone yard for my first turboproject and found a volvo 740 turbo. I can find any info on this anyonegot an idea what kind of tubo it is? Thnks
Old Apr 15, 2011 | 04:49 PM
enemy no1's Avatar
Default Re: Vovlo turbo
probably a t3 .42/.48 lol
Old Apr 15, 2011 | 04:58 PM
0c00l's Avatar
Is this it:
http://cgi.ebay.com/ebaymotors/1986-...#ht_8762wt_702
Old Apr 15, 2011 | 08:08 PM
lilrobie69's Avatar
I think so its from a volvo 740 wagon . What couldi expect from this turbo? Im lookin to do a b16 build
Old Apr 16, 2011 | 09:51 AM
skuded's Avatar
you shouldnt expect much, i believe the max they psi they put out in volvo is around 6psi, and they are very small, look into getting at least a t25 off of a mid 90s model eclipse, those turbos are a little bit bigger and i think would serve much more purpose than the volvo turbo
Old Apr 16, 2011 | 09:59 AM
Bizzle5OH3's Avatar
Even a T25 would be disappointing on a B16. B16 is known for its revving top end and that turbo would die out quick. Pretty much would be an in town car, worthless on the freeway and not much mid range power. At bare minimum if your dead set on getting a used turbo go with a 14B
Old Apr 16, 2011 | 01:35 PM
lilrobie69's Avatar
Ok so would my vovlo turbo work better for my d16 build and where do I get a reasonably priced 14b
Old Apr 16, 2011 | 01:40 PM
Turbo-LS's Avatar
dont bother with a junkyard turbo, plenty of other turbos out there to work well with a b16 engine. those tiny volvo turbos are going to spool quick and choke the crap out of that engine higher rpms. be better off with a straight t3 super 60 with a .63 turbine housing if you want really quick spool and dont have a huge hp goal in mind
Old Apr 16, 2011 | 03:51 PM
TheShodan's Avatar
Moderator
And a 14b can be found for $30 on dsmtuners, (which means its more than likely had the life beaten out of it) but they are even worse than the volvo you already have.
flangemastermike
May 31, 2006 11:51 AM
91rexdx
May 15, 2006 06:53 PM
twisted_jdm_b16
Jan 13, 2006 01:02 PM
themex77
Jun 16, 2005 10:01 PM
90 SiR Hatchie
Mar 12, 2004 02:38 PM
