b16 t3/t4 what kind of oil?
i'm sure this has been covered before, but i'm putting a t3/t4 on my b16. i was running royal purple 530, thinking of just running conventional 530. think this should be a decent choice?
should i go a higher viscosity, or will 530 do the job?
Re: b16 t3/t4 what kind of oil? (markaria)
5w30 and 10w30 are the same viscosity when hot.
5w30 and 10w30 should work fine if the engine is pretty much stock with the stock bearing clearences.
you could step up to a 5w40 or 10w40 for some added oil pressure since the engine oil will get hotter than normal with a glowing hot turbo in the system. slighly thicker oil wont hurt anything.
Man U FTW
i used Royal Purple 5w30 and it was too thin...it would pass the compressor side seal on hard boost for some reason...switched to 10w30 and i havent had a problem since
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">5w30 and 10w30 are the same viscosity when hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">i used Royal Purple 5w30 and it was too thin...switched to 10w30 and i havent had a problem since </TD></TR></TABLE>
lol this is why HT amuses me.
Man U FTW
Re: (ragethemachine86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 »</TD></TR><TR><TD CLASS="quote">
lol this is why HT amuses me.</TD></TR></TABLE>
I'm glad that amuses you, but the fact remains...i changed to a 10w30 and i haven't had any problems...i forgot to mention that it was a Mobil 1 oil i changed to
