b16 spool time
Old Oct 26, 2003 | 09:05 PM
redboost10's Avatar
Default b16 spool time
i was wondering when a turbonetics t3/t04e (.60 ar compressor, .63 ar exhaust, 60 trim with a stage 3 wheel) will start to spool on a b16a2 with a lovefab sst mani running about 10-12 psi? searched and only found b18c1 spool times. thanks for the help guys.
Old Oct 26, 2003 | 09:40 PM
redboost10's Avatar
Default Re: b16 spool time (tgh99si)
help me out here please.
Old Oct 27, 2003 | 08:26 AM
00sitk's Avatar
bumb cause i want to know too
Old Oct 27, 2003 | 08:33 AM
green_GSR's Avatar
It's hard to tell you exactly what RPM the turbo will spool. There are too many factors involved. Compression, ignition timing, cam timing, a/f, head, exhaust, etc. all contributes to turbo spooling.
Old Oct 27, 2003 | 09:03 AM
EpDarks's Avatar
Default Re: b16 spool time (green_GSR)
Are you running stock compression?
That's a good sized turbo, don't count on it spooling as fast on your 1.6 as it does on the B18C's.
As green_GSR said there are many factors contributing to spool time.
Old Oct 27, 2003 | 09:13 AM
redboost10's Avatar
Default Re: b16 spool time (EpDarks)
im using 9:1 compression, in general which turbo will spool faster, the t3/t04e .60 trim, stage 3 wheel, .63 ar exhaust or the t3/60-1 stage 3 wheel, .60 trim, .63 ar exhaust? is this trim too big for a b16a2 that wants 400 whp? please tell me the size of a t3/t04e and of a t3/60-1 that will spool quickly but still pull hard up in the 7000rpms.
Modified by tgh99si at 7:24 PM 10/27/2003
Old Oct 27, 2003 | 10:26 AM
redboost10's Avatar
why would the t3/60-1 be a better turbo for higher boost than the t3/t04e if the t3/t04e has the bigger exhaust housing than the t3/60-1? why do more of you guys recommend the t3/60-1? my goal is 400whp.
Old Oct 27, 2003 | 10:42 AM
hybridcrx's Avatar
Well....do you plan on 400 whp at 10-12 psi???? If so, I don't know if thats attainable at 9.0 compression. If you want 10-12 psi, get a t3. If you want 400 whp, I would say get a t3/t4, or maybe a super 60 t3.
You want to get the smalles tturbo that will reach your goals. Go too big and anyone with a brain will make fun of you for wasting your money and your shitty spool time.
Old Oct 27, 2003 | 10:51 AM
InTeGrA B18b1's Avatar
Default Re: b16 spool time (hybridcrx)
my ls with open dp with the 57 trim .60, .63 full boost at 4500-5k. so im thinking 4k ish
Old Oct 27, 2003 | 11:00 AM
SiRkid's Avatar
Default Re: b16 spool time (InTeGrA B18b1)
Friends car spools full boost at like 4200 rpm on his b16 w/ 57 trim .60/.63 a/r.
Old Oct 27, 2003 | 01:31 PM
drvfast's Avatar
Default Re: b16 spool time (SiRkid)
yea sir kid is correct around 4200
Old Oct 27, 2003 | 02:40 PM
redboost10's Avatar
Default Re: b16 spool time (drvfast)
so whats the difference between the t3/t04e and the t3/60-1? why is everyone going with the t3/60-1 over the t3/t04e? just wondering what the difference is and why a t3/60-1 is better on a b16 that will boost 10-20 psi. the t3/t04e spools at 4200 and when does the t3/60-1 spool? thank you all.
Old Oct 27, 2003 | 03:10 PM
ScrapinSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">my ls with open dp with the 57 trim .60, .63 full boost at 4500-5k. so im thinking 4k ish</TD></TR></TABLE>
similar to mine... b16a2 stock CR, .57 trim, .63 a/r, stage 3 wheel, full boost at about 4k-4500 rpms open downpipe.
Tchleung
Jul 23, 2004 12:49 PM
crxsir23
Jul 21, 2004 06:23 PM
HYBRID_H@TCH
Aug 26, 2003 12:30 AM
d98clturbo
May 26, 2003 04:52 PM
B20bTurbo
May 8, 2002 10:11 PM
