B-SERIES headlift question
Old May 31, 2005 | 05:36 PM
maxspeedhonda's Avatar
Default B-SERIES headlift question
Okay here is the deal...
A couple weeks ago I was on the dyno and we completing close to 50 runs. On two of those runs, the overflow puked on the dyno. Compression in the motor is perfect. No oil in coolant, no coolant in oil. No smoking. The overflor suggests headlift but I don't see how on 2 out of 50 runs at same boost level. I am thinking maybe the motor became heatsoaked. I have ARP headstuds and a GE HG, with a stock cooling system. What do you guys think?
Old May 31, 2005 | 05:49 PM
Boostage's Avatar
Default Re: B-SERIES headlift question (maxspeedhonda)
head tq'ed to spec?
Old May 31, 2005 | 07:23 PM
Default Re: B-SERIES headlift question (Boostage)
Yes sir, they should be. I torqued them initially when the Hg was installed and re-checked them a couple weeks afterwards.
Old May 31, 2005 | 07:31 PM
SOHCD16y8's Avatar
have you had any problems since? I would thinbk your ok if the oil is good and compression is ok. Did you do a leakdown test?
Old May 31, 2005 | 07:38 PM
Default Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">have you had any problems since? I would thinbk your ok if the oil is good and compression is ok. Did you do a leakdown test?</TD></TR></TABLE>
The overflow only happened on 2 runs about 2 weeks ago. It never happens while just running the car. It is a drag car that I can't exactly just drive down the street. No leakdown test yet, don't have a tester.
Old Jun 1, 2005 | 03:11 AM
Default Re: (maxspeedhonda)
bump
Old Jun 1, 2005 | 08:52 AM
JonnyCoupe's Avatar
Probably just boiled the water in the coolant system so it over pressurised and blew out the cap.
Old Jun 1, 2005 | 02:35 PM
Default Re: (JonnyCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Probably just boiled the water in the coolant system so it over pressurised and blew out the cap.</TD></TR></TABLE>
Thats what I am hoping..
Old Jun 1, 2005 | 02:38 PM
earl's Avatar
sometimes it just gets a little hot on the dyno and things happen. Sounds like you are fine.
Old Jun 1, 2005 | 02:52 PM
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">sometimes it just gets a little hot on the dyno and things happen. Sounds like you are fine.</TD></TR></TABLE>
Thanks Earl! Hearing that from you makes me feel much better!
Old Jun 1, 2005 | 03:31 PM
mamaboy's Avatar
did you drain your oil to double check for milk shake? no overheating?
98exowner
Sep 9, 2008 12:15 PM
blackeg
Mar 27, 2006 03:52 PM
revlimitx04
Nov 22, 2005 01:11 AM
primeredbeast
May 13, 2005 08:32 PM
1337 Si
Jan 14, 2004 07:03 AM
