b series build help
Old Dec 9, 2007 | 02:24 PM
TegProject's Avatar
Default b series build help
alright im getting ready to start a new build after i just blew the rings out of my b16.. i've done some reaserch and just wanted to hear some other opinons on what kinda setup i should run from your own experience... im going to go stock sleeves with piston/rods and i already have a b16 head ready... i also have the b16 block still in the car and i cant decide if i want to run the b16 again or a gsr, or b18 just need some advice... thanks.. also looked into maybe stroking the b16 a little...i've also looked into putting the ls crank in the gsr.. its going to be probably built for like 14psi. daily and im lookin for a little over 400whp... its mainly a street car.. also has a garrett t3/t4 powering it..
Old Dec 9, 2007 | 02:58 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: b series build help (TegProject)
your going to need a much bigger turbo to hit 400whp at 14psi...
Old Dec 9, 2007 | 03:37 PM
jmm96gsr's Avatar
Default Re: b series build help (tannerLSt)
GSR blocks are usually around $300- $500 depending on location and condition. I would try to find one and build it instead of building the B16 block. Then you can sell the b16 block to get money back.
TegProject's Avatar
yeah im eventually definitely upgrading the turbo but for now it'll be just the t3/t4 which the bottom end im sure could hold more than 14psi. with a good tune but it'll have mostly a daily tune on it...
Old Dec 10, 2007 | 10:46 AM
TegProject's Avatar
bump
Old Dec 10, 2007 | 11:34 AM
Schister66's Avatar
Man U FTW
so what's the significance of 14psi and 400whp...who cares what PSI it takes to hit 400whp as long as your setup is efficient. Most any 57-60trim will do that...
Old Dec 10, 2007 | 01:12 PM
TTT's Avatar
TTT
SILVER SURFER!! It will make 400whp in the 12-14psi range.
Old Dec 10, 2007 | 01:28 PM
Schister66's Avatar
Man U FTW
^^there you go
wagonstatus
Jul 15, 2007 01:08 PM
b16a4
Feb 5, 2007 12:43 AM
miragetsi
22
Jan 31, 2007 06:48 PM
MKcrxB16
25
Jul 20, 2006 11:36 AM
Dan GSR
Apr 24, 2003 08:39 AM
