AVCR Problem. (boost not regulated)
Old May 12, 2007 | 10:35 PM
  #26
Fitti's Avatar
Default Re: (Running925)
I'm sure you have also looked at the vacuum lines to the solenoid to make sure that they are not cracked or have a hole in them.
Old May 13, 2007 | 09:15 AM
  #27
Running925's Avatar
Default Re: (Fitti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure you have also looked at the vacuum lines to the solenoid to make sure that they are not cracked or have a hole in them.
they are all brand new, they came with the AVC-R, in the package, but yes, i have inspected them.
Old May 13, 2007 | 03:34 PM
  #28
Running925's Avatar
bump for mor help
Old May 13, 2007 | 04:23 PM
  #29
Blown90hatcH's Avatar
What size spring is in the wastegate? You will probably want to try and get another solenoid.
Jason
Old May 13, 2007 | 08:33 PM
  #30
Running925's Avatar
Default Re: (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">What size spring is in the wastegate? You will probably want to try and get another solenoid.
Jason</TD></TR></TABLE>
wastegate is holding the car at about 8psi when i disconnect the solinoid.
I'd hate to buy another solinoid for another $150 bux and have it turn out to not be the problem. Like i said earlier, apexi's test for the solinoid was to put a 12v power and a ground to it. "if it click's, it's good" is what apexi tech's said.
this is really frustrating.
Old May 14, 2007 | 06:55 AM
  #31
Running925's Avatar
Is there something special about that solinoid? I'm starting to wonder if i can test this thing by putting a 12v solinoid in there from my buddy's air ride setup on his truck....
yes.. starting to get desperate!
Old May 14, 2007 | 06:58 PM
  #32
Running925's Avatar
soo summit racing, one of the biggest sellers of automotive performance parts doesn't have an AVC-R in stock at any of their locations, let alone just the solinoid...
Old May 14, 2007 | 07:12 PM
  #33
Civicman86's Avatar
http://www.nengun.com/apexi/avc-r
There you go
HondaTeKnology
Aug 17, 2009 11:25 AM
eglsvtec23
May 1, 2007 11:15 AM
rudebwoy
Mar 17, 2007 12:53 PM
boosted-delslow
Jan 21, 2005 09:16 PM
miller
Aug 12, 2004 01:53 AM
