AVCR with external wastegate
Old May 7, 2007 | 07:32 PM
evans_art's Avatar
Default AVCR with external wastegate
i'm using apexi avcr for controlling TIAL external wastegate. where can i found the instruction for install the vacuum hose? i've try the hose diagram in apexi manual book. but i think there is a problem. when i set the setting at apexi off. the boost only can reach 0.2 bar.
Old May 7, 2007 | 07:40 PM
zman's Avatar
Default Re: AVCR with external wastegate (evans_art)
On the solenoid
COM - top port of the wastegate
NC - tee the vacuum line that goes from the turbo to the bottom port of the wastegate and route the tee'd line to NC.
Took me a while to get this right too...the instructions suck huge nuts.
Old May 7, 2007 | 08:56 PM
93hatched_projekt's Avatar
Default Re: AVCR with external wastegate (zman)
Off means your running off your wastgate spring , here's a simple diagram to make it easy.Keep in mind you can run the vacume off the turbo on the nc side for cleanliness
Old May 7, 2007 | 09:53 PM
evans_art's Avatar
Default Re: AVCR with external wastegate (93hatched_projekt)
thanks lot. i will try it soon...
EGcivic_95
Apr 9, 2011 08:16 PM
DaYZeD.1
Mar 28, 2008 06:54 AM
asiankid29
Oct 10, 2004 12:14 PM
jwcardy
Sep 5, 2004 02:06 PM
SolidSpruce
Aug 2, 2002 10:00 PM
