Assistance Needed: Understanding Boost Control: Engine not reaching target pressure
Old 11-25-2017, 07:55 AM
Bennsss's Avatar
Default Assistance Needed: Understanding Boost Control: Engine not reaching target pressure
Hey my buddy and I are new to Honda and we got a b16 with b18 head vtec 1000cc injectors holset hx40 turbo hondata s300 V2 electronic boost tial wastegate controller bought from a buddy of ours that had it running on 15 psi but had problems only doing 5psi now. I thought boost lines got switch possible rearrange them then hit 8psi with boost cut so we put back way they were still around 7-8 psi and boost cutting what the **** are we missing replaced distributor plugs vacuum lines car also idles up a little after you let but goes back down after you touch throttle off boost cut for cold and hot are set for 12psi just running a tune for 8-9ish right now but want to get the full 15psi when this problem or problems are worked out the boost control is tapped into intake manifold it all has work on this setup before just wondering if something stupid is messed up or computer wise we really live far from any Honda shops and don't have money either. Thanks for any help and will take any suggestions boost cut hits around 5k or so
Old 11-25-2017, 01:09 PM
2kdrift's Avatar
Default re: Assistance Needed: Understanding Boost Control: Engine not reaching target pressure
take it to a competent tuner
Old 11-25-2017, 07:13 PM
Bennsss's Avatar
we have 2 tunes for it where it was Dyno tune at like 2 months before we bought it so we know the tune is good just feel like something dumb is holding us up
Old 11-25-2017, 07:20 PM
2kdrift's Avatar
you said its hitting boost cut which can be caused by tune settings or variance in the boost controller which the tune would also control the settings for
Old 11-27-2017, 05:21 AM
Bennsss's Avatar
Old 11-27-2017, 05:24 AM
Bennsss's Avatar
Update switch boost controller lines around no longer boost cutting but only hitting 5-6 psi like boost controller is not connected anything thoughts will it just run wastegate spring pressure if no boost controller?? Or if controller is working why only 5 when it's tuned for 15
Old 11-27-2017, 09:12 AM
Moderator
TheShodan's Avatar
How a Boost Controller Works - TurbosmartTurbosmart
Old 11-27-2017, 10:40 AM
2kdrift's Avatar
You need someone that is familiar with boost controllers and your ems software(if using electric boost controller) to troubleshoot this is why I recommnded a tuner....if not start reading and learning we are not there to fix the problem it's your turn to start reading up learning and troubleshoot yourself
it does sound like controller was working when it hit boost cut. Could be inconsistent variance in boost controller due to weather which is completely normal. Read up on boost controllers how they work and how to control them in whatever ems you are using. since you don' want to take it to a proffesional
Listerofsmeg
02-10-2012 05:16 AM
bigtom388
11-21-2009 12:30 PM
justinCO
05-20-2009 06:11 PM
rudebwoy
01-07-2008 01:45 PM
Quick Reply: Assistance Needed: Understanding Boost Control: Engine not reaching target pressure
