ARP washer help!
Old 05-24-2012, 01:56 PM
JDMCIVIC919's Avatar
Default ARP washer help!
So I bought new arp headstuds and I can't find the washers. Basically I lost them. Do u have to use them? If so can I just get some normal washers like them? Or do they have to be the arp ones?
Old 05-24-2012, 03:07 PM
phaphon's Avatar
Default Re: ARP washer help!
Arp sells new washers
Old 05-24-2012, 04:50 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
To be able to torque them properly you need the washers that they supply.
Old 05-24-2012, 06:19 PM
I.couldnt get the same diameter n width washer from.like auto zone? I need my car running asap
Old 05-24-2012, 06:51 PM
DO IT ON ALL FOURS
I can assure you they won't have them. Do as you please, when the washer mushrooms out and splits or your strip the block from them not wanting the torque don't say I didn't tell you so. How do you misplace this type of stuff anyways?
Old 05-26-2012, 12:30 AM
EK9
Dc4LsTeG's Avatar
Yes order them from arp. Dont try and go the cheap way and try and get them from somewhere else it will only end up causing problems that will make things more expensive
DixieEF
02-27-2013 01:19 PM
cibao2ner
01-23-2010 03:32 PM
InDub
05-05-2007 05:21 AM
wildoutwhitegsr
18
02-17-2006 07:09 AM
freakin
10-30-2005 09:11 AM
Quick Reply: ARP washer help!
