arp rod bolts...
Old Sep 26, 2009 | 08:49 AM
rick_rabies's Avatar
I'm not Rick!
Default arp rod bolts...
hi, __________gsr
this morning i put new piston rings on pistons and inserted them in the cylnder
the eagle rods that are in there, iv read 30lbs and 40lbs of torque which is true? using 30w oil this time. reusing bearings also.
Old Sep 26, 2009 | 08:55 AM
non-VTEC's Avatar
Default Re: arp rod bolts...
depends which size rod bolts you have the torque specs will be diffrent.
3/8" rod bolts are about 45ft/lbs (or was it 43ft/lbs???)
5/16" rod bolts are 28ft/lbs
both those specs are used with arp moly assembly lube. if you only have engine oil the specs will be diffrent and no one will be able to give you an acurate spec.
Old Sep 26, 2009 | 08:58 AM
I'm not Rick!
it says 2000 1.5 on the bolt
not sure what size that is
Old Sep 26, 2009 | 11:00 AM
non-VTEC's Avatar
they all have those numbers on them.
the only other way to tell the two sizes apart is by the size socket you are using.
if you are using a 3/8" socket you have a 5/16" rod bolt. 28/ftlbs
if you are using a 7/16" socket you have a 3/8" rod bolt. 43-45ft/lbs
Old Sep 26, 2009 | 11:34 AM
I'm not Rick!
......i used an 11mm 12 point socket...i know i know
i dont have that standard stuff
Old Sep 26, 2009 | 12:47 PM
Tjabo's Avatar
A 7/16" 12 point bolt will accept an 11mm 12 point socket quite nicely. I thought mine were 11mm until the guy from Eagle corrected me. . .
Old Sep 26, 2009 | 12:49 PM
I'm not Rick!
k i torqued them to 42lbs. so im good. tanx yall
CaliforniaDad
Jul 11, 2011 12:17 PM
kornerk12
Jun 29, 2009 08:09 PM
b20vtech
Apr 20, 2007 08:51 AM
therealPROJEKTEG
Jun 7, 2005 05:10 AM
ladysman
Mar 21, 2003 12:08 PM
