Apexi turbo timer
Old Mar 2, 2005 | 07:26 PM
Bigbrad's Avatar
Default Apexi turbo timer
I bought a apexi turbo timer, and i need to install it. But the instructions are in Japanese and i can only read English. So if anyone knows where i could find the wiring diagram i would appreciate it. Or if they could tell me what color of wire goes where it would be really helpful thanks in advance.
Old Mar 2, 2005 | 08:01 PM
Evanmb44's Avatar
Default Re: Apexi turbo timer (Bigbrad)
try their website.....it should be on there i think
if not i have the instructions i can tell you what goes where tomorrow
Old Mar 2, 2005 | 08:12 PM
Bigbrad's Avatar
Default Re: Apexi turbo timer (Evanmb44)
Yeah i cheacked the website and i couldnt find anything. So if you could tell me where it the wires go it would be awesome.
Old Mar 2, 2005 | 08:52 PM
PrettyLude's Avatar
i don't think you looked good enough, its there
Old Mar 2, 2005 | 09:26 PM
egturbo's Avatar
Default Re: (PrettyLude)
i bought a harness from lightning i think and its plug and play works great
Old Mar 2, 2005 | 09:38 PM
Sprockets's Avatar
Default Re: (egturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo &raquo;</TD></TR><TR><TD CLASS="quote">i bought a harness from lightning i think and its plug and play works great</TD></TR></TABLE>
I thought about getting this for my Apexi, even though it's already hooked up, but what about the A/F meter?
Old Mar 2, 2005 | 09:52 PM
XSIintegra's Avatar
Default Re: (B16A Grenade)
I don't deny that you searched the site and found the tech section... Can be kinda confusing. Basicly, look it over a couple times, find out which wire is which and then test out the leads on the back of your ignition switch and basicly match them up. Mine was hell to install because nothing was working right, then I found I had bad ign. switch. If you have an troubles...post 'em
Old Mar 2, 2005 | 09:54 PM
egturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade &raquo;</TD></TR><TR><TD CLASS="quote">I thought about getting this for my Apexi, even though it's already hooked up, but what about the A/F meter?</TD></TR></TABLE>
i dunno.. i never hooked that up.. but battery option works i think u have to hook up a wire to the o2 sensor i need help on this also id unno which wire to hook up.
Old Mar 2, 2005 | 11:20 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo &raquo;</TD></TR><TR><TD CLASS="quote">i dunno.. i never hooked that up.. but battery option works i think u have to hook up a wire to the o2 sensor i need help on this also id unno which wire to hook up.</TD></TR></TABLE>
here's the link it tells you exactly which pin to connect it to
http://apexi-usa.com/productdo...r.pdf
Old Mar 4, 2005 | 05:21 PM
Bigbrad's Avatar
Thanks thats exactly what i was looking for. I had looked on the site but i couldnt find anything so thanks for the help.
Old Mar 4, 2005 | 08:48 PM
PrettyLude's Avatar
it tells you in the link i gave above, but it will only serve like an autometer a/f gauge, rich or lean
H22CB7
Oct 3, 2006 10:55 AM
b16hatche
Oct 21, 2005 04:58 PM
LagunaSecaEG
Aug 15, 2005 05:34 AM
TEG777
Jul 22, 2005 05:59 AM
BuiltB18C1
Oct 30, 2003 10:48 PM
