Apexi ACV-R
Old Oct 25, 2005 | 04:04 PM
hotimportcrx's Avatar
Default Apexi ACV-R
ok i happen to pick up one of these from ebay and all i have is the actual apexi acv-r blue box....and is there any more pieces to this????......and how do i hook it up???
There is
Grey Wire-
Purple Wire-
Black Wire-
White wire-
Red wire-
Green Wire-
Orange Wire-
Pink Wire-
Yellow wire-
Blue wire-
Brown wire-
Someone please help me out....i went to apexi site...but my comp really dont load to adobe pages...so someone helpppppppppppp
Old Oct 25, 2005 | 04:16 PM
Dee's Avatar
Dee
Default Re: Apexi ACV-R (hotimportcrx)
You need the Solenoid and Map sensor.
Grey Wire- Throttle
Purple Wire- RPM or Injector signal
Black Wire- Ground
White wire- Speed
Red wire- IG power
Green Wire- Ground
Orange Wire-
Pink Wire-
Yellow wire-
Blue wire-
Brown wire-
I will have to check my car for the map and solenoid wire colors.
Old Oct 25, 2005 | 04:19 PM
Default Re: Apexi ACV-R (Dee)
do you know where i can get the solenoid and map sensor.....and if i can just use a gm 3 bar map ensor?
Old Oct 25, 2005 | 05:24 PM
Dee's Avatar
Dee
I am not sure if the GM unit will owrk since the AVC-R is calibrated for a Denso 3-bar. A Denso map sensor will steal at least $150 from your wallet.
You can get the solenoid in the US. All you need is the solenoid that everyone is using for electronic boost controllers. It's the same item but cheaper.
Old Oct 25, 2005 | 05:41 PM
ok....any denso map sensor....and the solenoid can you give me a link to see which solenoid it is...and also..im gonna check if the screen works...if it doesnt is there a writeup to repair it ...i searched for about an hour but came up empty handed
Old Oct 31, 2005 | 04:25 PM
Dee's Avatar
Dee
Here's an update for you.
Grey Wire- Throttle
Black Wire- Ground
White wire- Speed
Red wire- IG power
Green Wire- Ground
Orange Wire- scramble boost
Pink Wire- Solenoid
Black wire - solenoid ground
Yellow wire- Map sensor
Blue wire- Map Sensor
Brown wire- Map Sensor
Old Oct 31, 2005 | 07:14 PM
seen4ever's Avatar
i have a working AVC-R map sensor for sale. when i bought mine, it didn't have one, so i bougtht a new one. only for 2 months later did the guy find the map sensor. So i ahve the stock map sensor for the avc-r if you are interested. I threw it on the car and works perfectly fine. PM me for pricing.
Old Nov 1, 2005 | 06:52 AM
Default Re: Apexi ACV-R (seen4ever)
ok i hooked the acvr up and the screen was not working...i also has a vafc...is there anyway i can use the display from that or bring it somewhere to get fixed?
Old Nov 1, 2005 | 07:07 AM
seen4ever's Avatar
do you have the grounds in the right order?
sounds like a wiring issue. download the directions via apexi-usa.com there is an order to how the grounds are wired and such.
Old Nov 1, 2005 | 07:19 AM
yea the wiring the right
spoolinvtec54
Nov 23, 2013 05:56 PM
aznryd3r
Nov 24, 2006 10:05 AM
T25 civic
Oct 6, 2002 02:11 PM
