apexi turbo timer is not function well enough?
Old Oct 11, 2002 | 05:51 PM
TurBoXBirD16's Avatar
Default apexi turbo timer is not function well enough?
I hoooked up the timer today..
the basic function worked.... alright
but that A/F and O2 thing isn't working
do i have to set up anything??
i followed the apexi instructions and tapped the O2 wire right out from the ECU...
my A/F light is flashing when i look at it.. it's 20 and light flashing...
I don't think I hooked up the right wire...
It's the WHITE WIRE from the sensor, but is it the same color on the ECU??
it's a D16Z6
Should I have just tapped it to the wire to my A/F Gauge?
Plz let me kow and help !!
thanks
P.S. I hate hate hate taking that ECU out.. those wires, that shield !! damn !! sucks !!
Old Oct 11, 2002 | 06:30 PM
LordVtec's Avatar
Default Re: apexi turbo timer is not function well enough? (xbird)
I had the same problem when i first installed my TT and it sounds like you arent getting a signal from your ecu o2 sensor signal wire.. check your connection and make sure you have a good connection... also make sure you connected it to the right wire.. the moment you have the right connection that flashing 20.0 will go away and you will get --- with the led flashing red and green.. once the o2 sensor warms up it should start giving you some readings... if i were you i would go back and check your connection.. (you probably either dont have a proper connection thanks to use of a vamp clamp, or you have it connected to the wrong wire..)
Old Oct 11, 2002 | 08:48 PM
Default Re: apexi turbo timer is not function well enough? (LordVtec)
how can i check which wire is correct??
i have the helms.. but it doesn't tell all the wires functions
Old Oct 11, 2002 | 08:51 PM
LordVtec's Avatar
if your gonna use the o2 sensor wire off the ecu you need to count the pins (use the wire diagram off of apexi's web site for your car...) thats what i did and it worked.. i just dont remember at this time what color wire it was... another option is to use a direct signal wire tapped into your O2 sensor wire... both will work..
Old Oct 11, 2002 | 09:29 PM
the TT instructions asks me to connect it from the ECU
does it make a difference??
coz i already have a a/f ratio gauge, maybe i can just tap the wire in??
thaks
Old Oct 11, 2002 | 10:06 PM
OH yeah.. so
there are so any settings for A/F O2 Battery Voltage...
i read the instructionssssss, i don't quite get what it means..
what are the settings for???
do i have to set anything?? thanks
Old Oct 12, 2002 | 11:19 PM
any body?
Old Oct 14, 2002 | 04:41 AM
would connecting it from the sensor be the same as connecting it from the ECU??
plz help
Old Oct 14, 2002 | 05:00 AM
senpai's Avatar
FAT white wire from ECU
Old Oct 14, 2002 | 06:03 AM
Default Re: apexi turbo timer is not function well enough? (maztur)
FAT white wire??
that means ALL white wire??
i connected it, it doesn't work...
how come??
Old Oct 14, 2002 | 06:15 AM
tmg's Avatar
tmg
don't tap any of the other sensored wire, i.e. other o2 wires from your other components. that white wire should be the power wire.
Old Oct 14, 2002 | 07:12 AM
LordVtec's Avatar
again i would suggest taking the specific ECU wire diagram from apexi and count the pins to figure out which is the right wire you need to splice.. your other option is to directy tap the o2 sensor.. (wont make a difference)
Old Oct 14, 2002 | 02:14 PM
i checked their diagram..
but they don't have D16Z6's diagram... sucker...
help help plz
accordianex
Feb 19, 2006 07:07 AM
spoonzdelsol
Oct 4, 2005 12:40 PM
stumbler
Feb 6, 2004 05:59 AM
Hybrid CRX
Jan 7, 2004 03:39 PM
TurBoXBirD16
Oct 10, 2002 09:16 PM
