APEX-I turbo timer
Old Jan 7, 2004 | 05:02 AM
monicle's Avatar
Default APEX-I turbo timer
Hey I just hooked up my turbo timer and I guess I need to set what the O2 sensor voltage is. I have a range on the installation guide as follows. 960, 940, 820, 450, 010, 006, 004, and 002. Which one do I use. 2k civic w/ b18c
Old Jan 7, 2004 | 05:29 AM
swlabhot's Avatar
Default Re: APEX-I turbo timer (monicle)
U don't need to touch it. Wire it up and check it should fluctuate up and down around 14.7 at idle, then u know it works.
Old Jan 7, 2004 | 06:07 AM
monicle's Avatar
Default Re: APEX-I turbo timer (swlabhot)
i thought I had to set it for my car so that it can calculate the AF ratio. It already reads battery voltage fine so I should just leave the O@ sensor coltage alone and it will calculate the correct AF ratio?
ImPuLsIvE
Oct 9, 2007 09:53 AM
LowTEC-Derbo
Nov 4, 2006 07:43 PM
honhatchisbak
Jan 9, 2005 09:01 AM
