anyone using a water cooled turbo?
Old Dec 14, 2003 | 08:42 PM
meanEG's Avatar
Default anyone using a water cooled turbo?
if you are where did you runthe coolant feed and return? i ordered a water cooled turbo for a ls/vtec i am building. just let me know and post pics if you got em
Old Dec 14, 2003 | 08:47 PM
_Endless_'s Avatar
Default Re: anyone using a water cooled turbo? (meanEG)
i ran mine inline with one of the hoses of the IACV.
Old Dec 15, 2003 | 05:19 PM
meanEG's Avatar
Default Re: anyone using a water cooled turbo? (_Endless_)
anyone else? where did you run the lines? around which side? did you use a t of some sort?
Old Dec 15, 2003 | 05:31 PM
aw1234dude's Avatar
When me and my friend installed a turbo kit in his impreza 2.5rs we just used the two hoses going to the heater core. I'm pretty sure you can use those same hoses when installing a water cooled turbo in a honda. Just go get two tee fittings and tee off from both heater core hoses on the back side of the engine going toward the firewall. It doesnt matter which one you use because your just looping the hoses.
Old Dec 15, 2003 | 06:20 PM
Bailhatch's Avatar
Default Re: anyone using a water cooled turbo? (aw1234dude)
why bother, it's just more lines to leak and cause reliability problems and make working on the motor a PIA. Just get a turbo timer and let her idle...
would the heater core line circulate when the heater control valve is shut or must you turn on the heat to boost
Old Dec 15, 2003 | 06:29 PM
gearhead313's Avatar
25 Year Member
Default Re: anyone using a water cooled turbo? (Bailhatch)
some motors have a sensor in the goose neck that comes off the head for the top rad hose. Take that sensor out and get a barb fitting and use that for the return.
The feed should come off of somewhere near the thermostat. The IACV line would probably be a good place to tap, just make sure its on the push side.
Old Dec 15, 2003 | 06:32 PM
BlueSi2k's Avatar
Default Re: anyone using a water cooled turbo? (gearhead313)
Im selling these stainless lines that tap into your heater hoses.
https://honda-tech.com/zerothread?id=686776
PM me if your interested.
Old Dec 15, 2003 | 06:44 PM
meanEG's Avatar
Default Re: anyone using a water cooled turbo? (BlueSi2k)
nice ideas i like em
Old Dec 15, 2003 | 09:17 PM
aw1234dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">would the heater core line circulate when the heater control valve is shut or must you turn on the heat to boost </TD></TR></TABLE>
No, the valve that opens the heater core hoses is after the point where you splice into them for the turbo water lines. This keeps the coolant continiously flowing even if you have the heater off or on.
Old Dec 15, 2003 | 09:44 PM
Johnyquest's Avatar
I am using a water cooled turbo w/o the water lines hooked up
10k miles still going strong, but I really should get them hooked up... but where to get the GIANT fittings... i lost one of the banjo bolts again!
GT500FTW
May 6, 2013 01:48 PM
thegatekeeper14
Jul 6, 2010 06:21 PM
honda_ftw
Aug 17, 2009 11:44 PM
95BoostedEJ1
Feb 22, 2009 08:15 AM
lojackgsr
Apr 27, 2008 03:03 PM
