anyone run low boost on an sc61?
Old Mar 13, 2004 | 09:32 AM
boosted jetta's Avatar
Default anyone run low boost on an sc61?
ok my car is gonna be running soon and i'm only gonna be running 7-10psi in the beginning and i have an ITS gts61 turbo (same as the sc61) my question is how will the turbo do at low boost? is it gonan completely suck?
thanks
Old Mar 13, 2004 | 09:46 AM
NateTEG95's Avatar
Default Re: anyone run low boost on an sc61? (boosted jetta)
My GS-R made 197whp at about 4lbs a few weeks ago, because my wastegate sucks. New one should be here Monday.
There are a few dynos (I think I searched for SC61 dyno) of GS-R's running low boost, all making just over 300whp at 10psi. I'd say it's not going to suck at low boost, but we'll see on Monday.
Old Mar 13, 2004 | 10:15 AM
JDogg's Avatar
Default Re: anyone run low boost on an sc61? (NateTEG95)
we did a 8psi sc61 b16 that made 300hp....
Old Mar 13, 2004 | 10:20 AM
Default Re: anyone run low boost on an sc61? (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">we did a 8psi sc61 b16 that made 300hp....</TD></TR></TABLE>
that's what i like to hear how does it feel though? my motor is a 2.0 16v with a 92.8mm stroke so it will be a torque beast, but it will only rev to 7,500rpms so my boost window will be like 4000-7000k
Old Mar 13, 2004 | 11:40 AM
m R g S r's Avatar
That should spool fine on a 2.0l motor.
Old Mar 13, 2004 | 12:44 PM
Mad Cow's Avatar
300whp at 8psi? What was the setup? Which housing?
Seems like a lot, I hope I'll get that much from my B18C.
Old Mar 13, 2004 | 04:30 PM
DLB1994's Avatar
Default Re: anyone run low boost on an sc61? (MadCow)
whats the bore size
Old Mar 13, 2004 | 05:01 PM
Unsung's Avatar
Default Re: anyone run low boost on an sc61? (DLB1994)
I'll be running .5 bar on my b16a. Got the car running today, just need to finish fab work on the charge pipes and the downpipe.
Old Mar 13, 2004 | 05:56 PM
JDogg's Avatar
Default Re: anyone run low boost on an sc61? (Unsung EM1)
on the b16 the power is realllllly high up in the rpms. it dosnt make full boost till about 5700rpms. its a completly stock block/head minus the valve springs/retainers.. we rev it to 9500 rpms. it would make more but we dont want to rev it more
on the old built 2liter motor we had in the car it spooled 20psi at 4800 rpms. im not sure this turbo would be good on a VW motor, those things arent known for their rev ability.
the setup for the b16 is.....
stock block, un ported head
crower valve train
overblown motorsports equal length manifold
jg intake manifold
precision sc61
revhard i/c
crappy hacked up i/c piping
tial 46mm wg
tial 50mm bov
64mm throttle body
precision 880cc injectors
aem ems
eurospeed performance coil on plug kit
tilton twin disk clutch/flywheel
and of course my tuning
Old Mar 13, 2004 | 06:03 PM
DIRep972's Avatar
Smarter than you
Innovative doesn't use Garrett wheels anymore, so don't expect it to behave just like an SC61.
Old Mar 13, 2004 | 08:49 PM
Default Re: anyone run low boost on an sc61? (DIRep972)
my innovative is built to the same specs as the sc61
Old Mar 13, 2004 | 08:52 PM
Arturbo's Avatar
Better than steak
25 Year Member
Innovative uses Garrett compressor wheels. I am not sure on the T3 turbine wheels but I know Innovative makes their own T04 turbine wheels.
Now, on the T4 turbines from Innovative it can have the same name as a P-trim but will not perform like the Garrett P-trim. So because it has the same specs or trim only means it has the same inducer and exducer size, but will not perform the same.......
art
Old Mar 13, 2004 | 11:42 PM
Justin Olson's Avatar
Default Re: anyone run low boost on an sc61? (Arturbo)
Well,
Peppy's turbo has a GT-40 56 trim compressor wheel. Dry center section and stage 5 (10 blade) turbine wheel. All that with a .63 a/r non port turbine housing.
Here are some pics if that would help:
Old Mar 21, 2004 | 08:22 PM
1SlowSi's Avatar
Default Re: anyone run low boost on an sc61? (Justin Olson)
What is the size of the turbine outlet?
Old Mar 21, 2004 | 08:26 PM
Unsung's Avatar
Default Re: anyone run low boost on an sc61? (1SlowSi)
K i got my setup running.... starts building boost at 3500, full boost by 5k... this was with a side exit exhaust, b16a, type r cams, stock bottom end, .5 bar.
Old Mar 22, 2004 | 09:23 AM
i'm hoping to see full boost by 4000-4500rpm max, my motor is a 2.0 with a 92.8mm stroke, so that should get it spolling a little faster than a honda motor
ej1252
Nov 2, 2007 02:41 PM
teddy_dc2
Aug 6, 2006 07:10 AM
flangemastermike
Apr 5, 2006 03:34 PM
Black R
Mar 25, 2005 07:23 PM
SiBirdie
Nov 8, 2003 05:15 PM
