Turning up the boost?
Old Nov 1, 2007 | 01:23 PM
ej1252's Avatar
Default Turning up the boost?
If i turn the boost up from 10PSI to 14PSI on a stock B16, knowing that the horsepower not gonna go over 300whp, it should be fine right??? Im about to get a 2Bar Map Sensor.
Old Nov 1, 2007 | 01:43 PM
urbansi's Avatar
Default Re: Turning up the boost? (ej1252)
are u just gonna turn up the boost, or are you having it tuned
Old Nov 1, 2007 | 01:55 PM
moores55's Avatar
Default Re: Turning up the boost? (urbansi)
if you up the boost, you must re-tune or it will blow up much faster then you would like.
Old Nov 1, 2007 | 02:01 PM
street dream gsr's Avatar
* B A N N E D *
Default Re: Turning up the boost? (moores55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 &raquo;</TD></TR><TR><TD CLASS="quote">if you up the boost, you must re-tune or it will blow up much faster then you would like.</TD></TR></TABLE>
Old Nov 1, 2007 | 02:34 PM
ej1252's Avatar
my fault, im gonna have it tune at 14 psi.
Old Nov 1, 2007 | 02:35 PM
ej1252's Avatar
o ok, but it will be fine when i tune it right since its stock???
Old Nov 1, 2007 | 03:04 PM
jfruauff's Avatar
nobody can really tell you that. Of course with a good tune the car is gonna be ok. But nobody can tell when a motor is just gonna break. Stock piston ring land are always a problem for a boosted honda
Old Nov 1, 2007 | 03:31 PM
adseguy's Avatar
Default Re: Turning up the boost? (jfruauff)
Torque is going to be so low that it'll be fine. I don't know why you're throwing 14psi at it. What turbo are you running? Is it really that small. Not that it's a problem, just wondering.
You could even do 400whp on a stock B16 cause they'll put out about the same torque an LS would at 300whp....and again torque is what matters.
Old Nov 1, 2007 | 03:46 PM
ej1252's Avatar
Default Re: Turning up the boost? (adseguy)
oo so torque is what matters, something new i just learned, well its a gt28r turbo, it brings the torque up pretty good, my tuner said the tq is gon be between 220-230wtq, im guessing that should be fine. thanks.
Old Nov 1, 2007 | 04:52 PM
urbansi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Is it really that small. Not that it's a problem, just wondering.
couldnt help it
Old Nov 2, 2007 | 02:38 PM
laziebun's Avatar
what if he tunes it for 14psi but then turns it down to 10 psi, is that possible?
Old Nov 2, 2007 | 02:41 PM
Schister66's Avatar
Man U FTW
Default Re: Turning up the boost? (laziebun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote">what if he tunes it for 14psi but then turns it down to 10 psi, is that possible?</TD></TR></TABLE>
The fuel and ignition maps are in place for everything under the highest PSI tuned...meaning you CAN turn it down without worry
teddy_dc2
Aug 6, 2006 07:10 AM
ras
May 3, 2005 09:14 AM
slo_crx
Oct 6, 2004 08:31 AM
BoostedH23a1
Aug 21, 2003 04:00 PM
