wideband 02??
Old 03-28-2004, 07:10 PM
JDMlyfestyle's Avatar
Default wideband 02??
I need to get a nice wideband o2 sensor for tuning. what is a good decent one without the outragious pricing?
Old 03-28-2004, 08:32 PM
jdmkevin's Avatar
Default Re: wideband 02?? (JDMlifestyle)
VX's and HX's had 5 wire O2 sensors. I believe many people use those, I'd imagine their relatively cheap from a salvage yard.
Old 03-29-2004, 09:03 AM
how would i wire that up cause i have a 4 wire o2 sensor now
Old 03-29-2004, 09:29 AM
Ricey McRicerton's Avatar
Default Re: (JDMlifestyle)
I suggest the Techedge widebands. That's what I use and I like it.
http://www.techedge.com.au/
Old 03-29-2004, 09:48 AM
how much does it run? aslo are the vx o2 sensors considered wideband?
Old 03-29-2004, 11:49 PM
any one else care to give input
Old 03-30-2004, 05:20 AM
EE_Chris's Avatar
Wideband O2 sensors need a controller box to operate. On stock VX's and HX's, this circuitry is inside the ECU. Simply installing one of these WB O2's in place of your existing 4-wire O2 will NOT work....which is why the TechEdge 'kit' has been suggested to you. The PLX Devices WB seems to be a popular option as well, which is also a 'kit'.
Old 03-30-2004, 05:29 AM
ahki's Avatar
is $550 considered rediculous?
PLX wideband at Hondata. Close loop and Wideband at the same time.
Old 03-30-2004, 06:59 AM
Default Re: wideband 02?? (ahki)
I got EVERYTHING I needed for my WB02 secondhand on here for just about 300 bucks.
I like mine.
It even has a narrowband output if you want to use the wideband sensor to supply your car with it's 02 sensor readings.
Old 03-30-2004, 09:48 AM
gdrum's Avatar
Default Re: wideband 02?? (Ricey McRicerton)
There are two group buys going on currently in sponserthread's. AEM UEGO(imo the best) with gauge 380 shipd and then the plx wideband which is recommended by hondata 320 shipd. Either of which are perfect. Hope this helps.
King V
11-30-2007 04:40 AM
DEMNTD1
03-01-2006 12:07 PM
kwiker
12-07-2003 10:26 PM
splitime
10-19-2002 05:24 PM
xhatchracerx
08-08-2002 03:17 PM
Quick Reply: wideband 02??
