Any suggestions...?
Old May 13, 2010 | 11:48 AM
Lzonk's Avatar
Default Any suggestions...?
ive been doin some research and i kinda have an idea of what id like to do. I wana run a fully built ls vtec motor with a jrsc. id like to get around 300hp or better.
I was wondering if i used toda vtec killer cams, would it run better with a jrsc? what cams would be ideal to use with a jrsc?
im not sure of which pistons to use. would you use dished pistons?
sorry, i know these questions are common and ive done my research but id like some ideas. Thanks
Old May 13, 2010 | 12:05 PM
Cloner's Avatar
Default Re: Any suggestions...?
If I remember correctly GSR/Type-r combo was the best.
Old May 13, 2010 | 03:48 PM
90blackcrx's Avatar
Either use Type R cams, or skunk2 pro 1's , depending on budget.
Old May 14, 2010 | 04:21 AM
90Rexx's Avatar
if your building the block, go with a sleeved block and high compression pistons.... get a good tune... and enjoy your beast.
Old May 14, 2010 | 12:16 PM
90blackcrx's Avatar
High compression pistons on a turbo setup.... Um, no.
Old May 14, 2010 | 04:54 PM
TheShodan's Avatar
Moderator
He probably means higher compression than usual. like 10.X:1 or something to that effect
Old May 17, 2010 | 07:01 PM
Lzonk's Avatar
like ctr pistons? ive heard u wana used dished pistons...? im not sure what would be good and reliable
Old May 17, 2010 | 07:22 PM
TheShodan's Avatar
Moderator
On JRSC, you want slightly high compression, not "dished" low compression pistons. the rules are a little different for supercharger because you need the compression to get linear power. 10.8:1 is fine with type R or GS-R Cams. you need to be more concerned with intercooler or aftercooling for it to get 300whp.
Lzonk
May 13, 2010 05:18 AM
ITRiWISH
May 11, 2008 07:36 PM
BLK99VTECR
Dec 16, 2003 12:47 PM
P1mpSlap
Apr 18, 2003 12:48 PM
CIVILGSR
Dec 2, 2002 07:38 PM
