any opinions?
i have a b16 in a 91 h/b. i want to run about 8 psi nothing big. I was thinking a t3 or something. Not sure what a good manifold would be so heres where i need a little bit of help.
What would you use? for low boost with the option of high for a t3.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ateyour2JZ »</TD></TR><TR><TD CLASS="quote">Search</TD></TR></TABLE>
Holy **** his 1st post is telling you to search. Way to contribute
Anyway, If I were you I would just buy a kit, like maybe the Greddy. Or if you want to upgrade down the line and want to run some higher boost levels maybe an Fmax or Drag. Both those use the external wastegate and come with bigger turbos than the Greddy. Good Luck
thanx man
I just found out that log style are good for fast spool with decent hp for small turbos. Which is exacly what im looking for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
Anyway, If I were you I would just buy a kit, like maybe the Greddy. Or if you want to upgrade down the line and want to run some higher boost levels maybe an Fmax or Drag. Both those use the external wastegate and come with bigger turbos than the Greddy. Good Luck</TD></TR></TABLE>
