Any one else have a turbocharged honda w/ factory internals need of tech info
I have a boosted accord, and i was curious about the reliability and longevity if the motor when you are daily driving on stock internals..how long is the estimated time that the motor will hold up...I ahve been told 1 year maybe less....is this true??
Re: Any one else have a turbocharged honda w/ factory internals need of tech info (dustin)
In maximum boost it says that you "should" expect up to 90% of normal engine life when boosted...
That's assuming you are on a perfect tune, have quality parts/installation, use the appropriate octane gas, are within a safe boost range etc...
There are so many factors to consider... if you do it right, you can expect quite a bit of life from your turbo setup...
In my experience, most people either get bored and turn up the boost beyond a safe level, which blows the engine, or they build another engine before the stocker gives way...
Re: Any one else have a turbocharged honda w/ factory internals need of tech info (EJ1 wilcox)
F23A4 stock internals, homemade .043" headgasket and 11 psi for 15,000mi and a year now. MF2 for fuel management, street tuned.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Any one else have a turbocharged honda w/ factory internals need of tech info (projectxaccord)
It could last 5 seconds, or 5 years.
Depends on a bunch of factors, most of them are within your control.
Re: Any one else have a turbocharged honda w/ factory internals need of tech info (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">It could last 5 seconds, or 5 years.
.</TD></TR></TABLE>
Tuning and Your HP goals will be the deciding fatcor
Phil
.</TD></TR></TABLE>
Phil
pjr710
01-05-2009 11:15 PM
