Turbo sizing for F22
Old May 11, 2009 | 09:28 AM
cpl rampage's Avatar
Default Turbo sizing for F22
Kind of curious on turbo sizing for F22's. I have a T3/T4 57 trim on my built D16, and that obviously is a lil large and spools a little late but is good for what I use it for.
Now I have a friend with a F22, he is asking me to help him out a bit, but i really don't have any experience with anything larger then a 1.8l B series. He found a deal on a Garrett T3/T4 turbo with a .50 a/r compressor housing. I am talking to the seller and trying to get the trim and turbine housings but hes at work right now. But in general, for a T3/T4 on a F22 from an accord ex, what kind of spool are we looking at? I know its not a small turbo, but its not a tiny one either. I would think that with his increased displacement and a smaller turbo then me it would build boost fairly quickly, maybe 3000-3500?
He uses it as a daily driver and wont be making any crazy numbers, but would like to give his 4 door some get up and go.
i will post up the complete specs as soon as i get them. and hopefully I can find a flow map.
Old May 11, 2009 | 10:28 AM
Schister66's Avatar
Man U FTW
Default Re: Turbo sizing fo F22
With a 50trim on that F22, he should have pretty good spool...I would have to imagine it would be in the 3-3500range like you said. Think of it like a 2.2L D series...
Old May 11, 2009 | 11:16 AM
Lol its true, d series is the lil brother to b series and F is to H lol.
Well now that that's cleared up, what kind of power have people Put down on this engine? He wants to run it stock, with some Arp studs, i dont see him running any more then 6-8 psi, as long as that's safe on these engines.
Old May 11, 2009 | 11:51 AM
twkdCD595's Avatar
Default Re: Turbo sizing for F22
He would be fine with 6-8 psi on a 50 trim... given the obvious supporting mods and proper tuning are present.
You really would not even need the headstuds for what that 6-8 psi on a 50 trim would equate to in power by my guesstimation from playing with F's for a while now.
Old May 11, 2009 | 12:07 PM
Turbo-LS's Avatar
Is it really a garrett turbo or is it an ebay 57 trim with a .50 a/r compressor housing? the a/r isnt the trim either. is the size of the compressor housing.
on a single slam accord motor a 50 trim t3/t4 with a b cover aka .50a/r would be pretty decent. spool good and make ok power. id opt for a 57 trim with an E cover aka .60a/r compressor housing personally for a little more flow up top but thats up to the person where they want their powerband to be
Old May 11, 2009 | 12:12 PM
that's the thing, i have a legit garret i ordered from a garret dealer, the one he is looking at looks legit in the pictures but i told him to ask for a picture for the serial plate. And i know trim and a/r are not the same thing, Ive been boosted for awhile now and did a lot of research when i built up my engine. But both are essential to figuring out how much this turbo actually flows and responds.
on as side note, he has a 95 accord ex, that means he has a F22B1 SOHC VTEC correct? does this have the equal exhaust port spacing or the odd ball spacing? ew looks like im right, it has the un-even port spacing... can some one confirm this?
Old May 11, 2009 | 12:20 PM
twkdCD595's Avatar
I can confirm you are correct, it would be an F22b1 sohc vtec.
port spacing... 0 00 0
Old May 11, 2009 | 12:27 PM
I guess the best option for him is the ebay cast manifolds which work fine, but the 0 00 0 spacings ones are a bit more money then the equal port spacing ones, ghey.
one more question since you are very knowledgeable in accords, does a P28 plug right in to the stock harness?
Old May 11, 2009 | 01:27 PM
Turbo-LS's Avatar
p28 should plug right in, they all use the same plugs and cases just different internals
Old May 12, 2009 | 04:40 AM
twkdCD595's Avatar
Yes it does, just have to swap A6 (02 heater) and A11 (egr solenoid) pins.
Old May 12, 2009 | 04:47 AM
Well i think i have everything i was looking for, are there any other special considerations in regards to turbocharging and tuning his accord that would be different from any other honda?
bloodydc2
Apr 12, 2006 08:03 PM
bearboy80
Apr 4, 2003 04:39 PM
metal-x
Nov 26, 2002 01:01 PM
M.A.R.C.
Jun 10, 2002 03:23 PM
