Another Stock Sleeve Boost level Question
Old Jan 18, 2006 | 04:11 PM
Topdawgg's Avatar
Default Another Stock Sleeve Boost level Question
Im shootin for anything around 350-400whp with my setup, and im thinkin im gonna run around 1 bar of boost...
So im wonderin if my setup should be able to handle 14.7 PSI of boost..
b18A block stock sleeves
81.5mm Wiseco 9.2:1 Pistons
Eagle H beam Rods
Arp Head Studs
garrett t3/04e 60 Trim .63 A/R
Stock B16 head, Gsr Cams
RC 750cc Injectors
Ram Horn Custom manifold
Tuning with Uberdata..
Anything else you guys recommend for reliability, besides a good tune of course
Old Jan 18, 2006 | 04:20 PM
_entropy's Avatar
Default Re: Another Stock Sleeve Boost level Question (Topdawgg)
Search, this has been covered a trillion times. Boost pressure has no relation to sleeve failure, and stock sleeves have been pushed to over 600 WHP.
Old Jan 18, 2006 | 05:24 PM
11psiTurboSI's Avatar
Default Re: Another Stock Sleeve Boost level Question (_entropy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _entropy &raquo;</TD></TR><TR><TD CLASS="quote">Search, this has been covered a trillion times. Boost pressure has no relation to sleeve failure, and stock sleeves have been pushed to over 600 WHP.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _entropy &raquo;</TD></TR><TR><TD CLASS="quote">Search, this has been covered a trillion times. Boost pressure has no relation to sleeve failure, and stock sleeves have been pushed to over 600 WHP.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _entropy &raquo;</TD></TR><TR><TD CLASS="quote">Search, this has been covered a trillion times. Boost pressure has no relation to sleeve failure, and stock sleeves have been pushed to over 600 WHP.</TD></TR></TABLE>
Old Jan 18, 2006 | 05:26 PM
AaronJ's Avatar
Motors can't take a certain amount of "psi", they reach their limit with horsepower. Your setup should be fine for 400 hp with a good tune, but from what I have read about the t3/t04e turbos, it will probably take you about 16-18 psi to get you 400 hp.
Old Jan 18, 2006 | 05:28 PM
Topdawgg's Avatar
Default Re: Another Stock Sleeve Boost level Question (AaronJ)
even with the 60 trim .63 A/R version of it?
Old Jan 18, 2006 | 05:53 PM
AaronJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">even with the 60 trim .63 A/R version of it?</TD></TR></TABLE>
As far as i know, yes. That is the same turbo I plan on running
Don't worry, your motor will take 400hp no problem.
Old Aug 1, 2006 | 11:05 AM
standinghollow's Avatar
hondacura22
Apr 9, 2009 08:30 AM
T3-T4TEG
Apr 21, 2004 04:01 PM
B18 CYA
Apr 7, 2004 03:43 PM
projectTeG
Nov 7, 2003 06:56 PM
1.8T_EG
Feb 5, 2003 12:52 PM
