Another Golden Eagle thread..........
Old Oct 9, 2003 | 05:39 AM
  #26
intekragsr's Avatar
Default Re: Another Golden Eagle thread.......... (tony1)
Thanks tony, your giving me hope. Im going to check the valves after school.
The reason im pointing my finger to the rings is because when I added oil to the cylinders, the compression jumped up.
Old Oct 9, 2003 | 05:49 AM
  #27
quikB18B's Avatar
Damn i hate seeing all these threads on built motors, they seem to be more and more common lately. It makes me wanna say **** it,and just keep rolling stock motors, if it blows another stock block. Sorry to hear about that man .
Old Oct 9, 2003 | 05:57 AM
  #28
PM-Performance's Avatar
Default Re: Another Golden Eagle thread.......... (quikB18B)
mine was the same results, but my cyl 3 was leaking out the dipstick tube . i was hoping it was valves too. youll find out when you rip the head off.
Old Oct 9, 2003 | 06:30 AM
  #29
Bnjmn's Avatar
Default Re: Another Golden Eagle thread.......... (intekragsr)
From my experience I would take the engine apart and check the piston clearnances and the bore straightness/taper. In my experience (my block) their clearances were pulled out of a hat, luckily too small, and I had to have them re-done. If yours are too big oil would've helped seal up the gaps and help your numbers.
Ben
Old Oct 9, 2003 | 06:55 AM
  #30
BoneStckCivic's Avatar
Well I had Golden Eagle do my block and i also heard of a few people's sleeves dropping but more and more times i continue to hear more problems..... Well i hope all goes well for me on the dyno will find out soon enough how well they built my block.
Old Oct 9, 2003 | 07:00 AM
  #31
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I agree with vapor, it doesn't sound like rings. If a ring was broken on assembly then i could see a problem, but not on 3 cylinders. I'd double check everything on the head. Make sure the valves lash isn't too tight, that could do it too. If the lash is good, then you're gonna have to pull the head. If everything looks peachy with the cylinder walls then take your head to a good machine shop and have them check it out.</TD></TR></TABLE>
If the valve lash is too tight will it show up on a compression test also??
Old Oct 10, 2003 | 08:50 AM
  #32
turbo*s2k's Avatar
Default Re: Another Golden Eagle thread.......... (sporkcrx)
I'm really surprised GE (Vince) hasn't responded to your thread!
Old Oct 10, 2003 | 09:06 AM
  #33
ladysman's Avatar
Default Re: Another Golden Eagle thread.......... (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">From my experience I would take the engine apart and check the piston clearnances and the bore straightness/taper. In my experience (my block) their clearances were pulled out of a hat, luckily too small, and I had to have them re-done. If yours are too big oil would've helped seal up the gaps and help your numbers.
Ben</TD></TR></TABLE>
Exact reason I had my machine work done at Endyn. Larry even said he has seen some horendous (spelling) machine work come from there. I didn't want to take the chance. I had Reher Morrison do mine.
Old Oct 10, 2003 | 11:03 AM
  #34
BodyKits NW's Avatar
Default Re: Another Golden Eagle thread.......... (ladysman)
Vince is on vacation.
Old Oct 10, 2003 | 11:10 AM
  #35
Kwuaymaikrup's Avatar
Default Re: Another Golden Eagle thread.......... (BodyKits NW)
My block is supposed to be finished this week. I am going to have thorough examination of it before putting the head on. I'll let you know how it turns out. Hopefully I have better luck than you.
-Ryan
Old Oct 10, 2003 | 12:46 PM
  #36
b18bturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">Vince is on vacation. </TD></TR></TABLE>
I think he is with the bergenholtz for extreme rush
Old Oct 10, 2003 | 12:51 PM
  #37
twkdCD595's Avatar
Default Re: Another Golden Eagle thread.......... (b18bturbo)
GE has never seemed bashful about addressing any other situations or what not.
If anything you have to give them credit for not handling things like JG.
I hate when people try to tell you it is raining when they **** on your leg though... someone should realize it is a problem and not to just keep running it 5-600 miles more.
Old Oct 10, 2003 | 12:57 PM
  #38
intekragsr's Avatar
Default Re: Another Golden Eagle thread.......... (twkdCD595)
Im not pissing on anyones leg, and I have not driven 5-600 miles. Yes, I sure do know its a problem, and thats why I created a thread.
Old Oct 10, 2003 | 01:12 PM
  #39
TurboDANDEE's Avatar
im gonna recheck my leak down test. last time i did mine, it was 30-40% on #2 #3, 15% on #1 #4, GE sleeves Cometic gasket. i thought i had a leaky HG or a fucked up leak down tester. i have now a new head/valvetrain and GE HG, im gonna recheck the leakdown when i get a chance...
intekragsr: are u losing coolant and have heating issues? losing oil also?
Old Oct 10, 2003 | 01:20 PM
  #40
twkdCD595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">Im not pissing on anyones leg, and I have not driven 5-600 miles. Yes, I sure do know its a problem, and thats why I created a thread. </TD></TR></TABLE>
Dude you took it wrong... I meant ge was bsing you not telling you a straight answer on the phone. I understand your position completely and was simpathizing with ya.
Old Oct 10, 2003 | 01:39 PM
  #41
intekragsr's Avatar
Sorry about that. Im just not in the greatest mood these days. I just re-read and on me.
Old Oct 10, 2003 | 01:40 PM
  #42
intekragsr's Avatar
I just did the valve lash. They were slightly out of spec. Rechecked compression and got the same results.
Im not burning any coolant, but I am burning a slight amount of oil. I still get people who tell me I smell like burnt oil at work, but I guess Im immune to the smell now.
Old Oct 10, 2003 | 02:34 PM
  #43
intekragsr's Avatar
I guess my only option is to wait for Vince to come back.
Old Oct 10, 2003 | 03:38 PM
  #44
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Honestly, maybe turbo Hondas aren't for you man. I've never heard of anyone as unlucky (not dumb, just unlucky) as you are when it comes to boost. Perhaps you should sell your GSR, your other motors and your turbo setup and get an EVO or STi with all the money you've spent? Just a thought, not a flame.
Old Oct 10, 2003 | 09:17 PM
  #45
intekragsr's Avatar
Default Re: Another Golden Eagle thread.......... (boostincoupe)
I was just thinking that.....
Old Oct 15, 2003 | 04:09 PM
  #46
Austin's Avatar
I saw your engine when Lawrence was working on it...bummer man. Any response from Golden Eagle?
Old Oct 15, 2003 | 06:51 PM
  #47
intekragsr's Avatar
Default Re: (Austin)
nope. no response yet. Im going to follow up again tommorow. Vince was supposed to be back today from vacation.
Old Oct 15, 2003 | 07:27 PM
  #48
saso
Guest
Posts: n/a
Default Re: (intekragsr)
Break that motor down, don't get frustrated this is part of the game. If the sleeve sunk Im sure GE will get it fixed. Also give us feed back on what happens.
Old Oct 15, 2003 | 08:10 PM
  #49
X-Mazda 3 Racer's Avatar
Default Re: (saso)
Hey guys, sorry for not posting any sooner. I just got back in town and I am beat. Give me til tomorrow so I can get my head screwed on again. Thanks
Old Oct 16, 2003 | 01:53 AM
  #50
intekragsr's Avatar
Default Re: (GoldenEagleMfg.com)
