ANOTHER GENIUS IDEA!!!!! by me...! Intercooler...(Custom)
Old Feb 24, 2004 | 04:29 PM
  #26
DeadLock23's Avatar
ok for those who paint the IC, do you use heat disipating black paint? or just paint?
and if you do use heat disipaiting paint where can I get some?
Old Feb 24, 2004 | 04:30 PM
  #27
pip9's Avatar
Default Re: ANOTHER GENIUS IDEA!!!!! by me...! Intercooler...(Custom) (Irishweird00)
nm, its was a pwr intercooler but here's the thread: https://honda-tech.com/zero...49394
  #28
Mad Cow's Avatar
Default Re: (Irishweird00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">I think it would be just as efficient as a front mount... If you have a induction that flows to it.. to feed it more air......</TD></TR></TABLE>
It doesn't matter, it's a design flaw. The air, wether you make a scoop that goes under your car or not, it will not get as much air, and the airflow will not be uninterrupted as it would be if you ran a front mount.
Old Feb 24, 2004 | 04:35 PM
  #29
pip9's Avatar
Default Re: (DeadLock23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadLock23 &raquo;</TD></TR><TR><TD CLASS="quote">ok for those who paint the IC, do you use heat disipating black paint? or just paint?
and if you do use heat disipaiting paint where can I get some? </TD></TR></TABLE>
buy some radiator paint.
Old Feb 24, 2004 | 04:38 PM
  #30
Irishweird00's Avatar
Banned
Default Re: ANOTHER GENIUS IDEA!!!!! by me...! Intercooler...(Custom) (pip9)
Thank you.... I totally forgot about that thread, I remember looking at it awhile back but didn't think of it....
Earl is the man!
Old Feb 24, 2004 | 05:47 PM
  #31
Cee_mon's Avatar
Even if you paint just the end tanks black, its is hard to see it.
Here is a pic normally
And again but with the flash to see whats really there.
Old Feb 25, 2004 | 12:16 AM
  #32
Boosteddc2gsr's Avatar
good luck
Old Feb 25, 2004 | 03:54 AM
  #33
jmal1919's Avatar
Its a nice idea. I kinda of thought about something like that too, or maybe a v-mount, but honda's don't have that much room in the engine bay. Also, if you were able to mount a custom intercooler up high in front of the radiator, wouldn't that block air flow to the radiator and possibly cause over heating problems on a daily driver?
Old Feb 25, 2004 | 04:46 AM
  #34
Chillinit's Avatar
ok...aftering reading ur Custom setup idea..I'm wondering if this will intercooler will actually work efficently being in the engine bay....I mean..ur talking about mounting it where ur ac compressor sits?? With the crazy heat generated from a force induction setup.....won't this contribute to crazy heat soak??? will the intercooler even cool anything....any thoughts?
Old Feb 25, 2004 | 06:18 AM
  #35
ykracing's Avatar
Default Re: ANOTHER GENIUS IDEA!!!!! by me...! Intercooler...(Custom) (Chillinit)
I would tend to disagree with most of the people here... I think that if properly ducted, there is no reason that this wouldnt work...
However, the downside (that others have mentioned) is that you now have an IC being constantly heated from behind by a huge heater (turbo/manifold)...
So think that efficiency and heatsoak would be the major flaws in this idea...
I would seriously consider a nice Air/water setup if you are that concerned about people seeing it... because the space where the AC is would allow for a HUGE heat exchanger...
thats my opinion...
Old Feb 25, 2004 | 07:09 AM
  #36
Banned
Default Re: ANOTHER GENIUS IDEA!!!!! by me...! Intercooler...(Custom) (trboCIVICWRX)
I have thought about using a Air-water intercooler, but since this car is driven everyday... to and from work/college... don't think it would work to well
thanks for all the comments everyone.
Old Feb 25, 2004 | 08:32 AM
  #37
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">I have thought about using a Air-water intercooler, but since this car is driven everyday... to and from work/college... don't think it would work to well
thanks for all the comments everyone.</TD></TR></TABLE>
What about the air-to-water aftercooler scares you? It's exactly like a radiator, only smaller and dealing with more heat, and your radiator doesn't have issues on a day-to-day basis, does it? Just get the Vortech aftercooler and forget about custom mounting and custom building end tanks, etc. It's known to support up to 525hp and, from my roommate's Typhoon as an example, I can tell you that air-to-water aftercoolers do an insane job of cutting degrees off of the air charge.
Old Feb 25, 2004 | 08:41 AM
  #38
Banned
Default Re: ANOTHER GENIUS IDEA!!!!! by me...! Intercooler...(Custom) (Archidictus)
well it doesnt scare me... I'm just not sure how they work.... I've seen people use the vortech aftercoolers though... and making well over 400whp.
Old Feb 25, 2004 | 09:34 AM
  #39
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">well it doesnt scare me... I'm just not sure how they work.... I've seen people use the vortech aftercoolers though... and making well over 400whp.</TD></TR></TABLE>
They run off of a seperately sealed fluid system, driven by a smaller kind of water pump. It's basically a super-thick-core radiator that acts as a fluidic heat sink to draw tons of heat out of the air charge. Drop super cold water in it and feel the powah!
Old Feb 25, 2004 | 09:54 AM
  #40
ThePro's Avatar
Like said above.
Air-To-Water is wayyyy more effective at lowering the intake charge than an Air-To-Air system. And like I had said a page ago, it isn't really a problem until you get heat soak. And that won't be a problem going from home to school. And then when you drag race, stick some ice in that system and you got frosty air going to the engine.
Old Feb 25, 2004 | 10:21 AM
  #41
Quad-Damag's Avatar
Default Re: (ThePro)
People don't even know im turbo till my HKS blows off
Old Feb 25, 2004 | 11:12 AM
  #42
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro &raquo;</TD></TR><TR><TD CLASS="quote">Like said above.
Air-To-Water is wayyyy more effective at lowering the intake charge than an Air-To-Air system. And like I had said a page ago, it isn't really a problem until you get heat soak. And that won't be a problem going from home to school. And then when you drag race, stick some ice in that system and you got frosty air going to the engine.</TD></TR></TABLE>
I understand that its 100 times better, but im not going to be able to drop in some ice everytime i take a drive... an figurings heat soak will occur... id rather have an air to air setup.
Old Feb 25, 2004 | 11:51 AM
  #43
ThePro's Avatar
I understand that its 100 times better, but im not going to be able to drop in some ice everytime i take a drive... an figurings heat soak will occur... id rather have an air to air setup.</TD></TR></TABLE>
Yeah. The A2A looks way more agressive. Ice in the A2W system is only recommended for racing because condensation could screw with things. Heat Soak only occurs when the water approches near boiling. You wouldn't have a problem.
But the A2A does look better.
92civtegra
Sep 13, 2008 05:18 PM
wernhersey
Sep 13, 2007 10:26 AM
ATS*Mark
Sep 4, 2004 01:39 PM
crashtest Sonny
Jul 4, 2003 07:51 PM
hybridb18
Apr 6, 2003 01:16 AM
