another case of bad rings?
Old Sep 3, 2005 | 02:32 PM
ICeDoUt's Avatar
Default another case of bad rings?
just double checking.
I have bluish smoke coming out of my exhaust and my catch can is completly full.
Thats all i can think it is. So i guess its time to strip it down and replace? Also the motor is fairly new, i'd say around 2000 miles on it. so would reusing bearings be alright? any feedback, lemme know
Old Sep 3, 2005 | 03:07 PM
unieizm's Avatar
Default Re: another case of bad rings? (ICeDoUt)
Have you done a leak down and compression test on it yet
Old Sep 3, 2005 | 03:13 PM
primeredbeast's Avatar
find out why they're bad before you go and tear it all apart talk to whomever built the motor as well
Old Sep 3, 2005 | 03:27 PM
OMG B16's Avatar
Did you break it in properly, run a compression check and leakdown..
Old Sep 3, 2005 | 03:29 PM
B18 WES's Avatar
Default Re: another case of bad rings? (primeredbeast)
I had the same thing with my setup running boosted ls/vtec and it was not the rings but actually a valve seal was bad on my exhaust side allowing oil to get in and burning it.
Old Sep 3, 2005 | 04:14 PM
ICeDoUt's Avatar
Default Re: (Sick00SiCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick00SiCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Did you break it in properly, run a compression check and leakdown..</TD></TR></TABLE>
everyone has a different break in procedure. Gonna do a compression check tommorow
RedCd5TX
May 10, 2008 06:14 AM
PTR1
Jul 8, 2004 11:29 AM
fastfu
Jun 30, 2004 11:59 AM
DANG YO
Nov 24, 2003 04:26 AM
S2KP
Oct 24, 2003 03:39 AM
