another built D coming up
Old Apr 4, 2006 | 08:26 PM
turboeg77's Avatar
Default another built D coming up
finally starting with my new build up, im hoping to make it past 300hp on a Built D
heres some pics.
set up:
garrett GT2540r
srp pistons
eagle esp rods
arp head bolts
adj cam gear
newly re-built motor with block posting
my old turbo kit minus the t3/t4
clutch net stage 2
750cc lucas injectors
aeromotive fuel reg
bosch fuel pump
bg fuel filter
AEM EMS w/ boost control solenoid
ported cylinder head
do you think this thing will see some 300hp dyno graphs
Old Apr 4, 2006 | 08:40 PM
JDM-Civic-Hatch's Avatar
Im about to finish my motor tomorrow. its also a d series. i have a d16z6 with port and polished head, ARP head studs, Eagle H beam rods with decked/honed/notched block. Blockgaurd, stainless steel valves, skunk 2 adj cam gear, SRP pistons, JE rings, OEM gaskets, bearings, and seals.running a .60 AR t3/t4 garrett. pushing for 315-350. Greddy profec b spec II boost controller, and turbo timer. Crome Pro tuned. keep updates. ill send pics.
Old Apr 5, 2006 | 03:18 AM
AbitAvenger's Avatar
I think you can do it
Old Apr 5, 2006 | 07:23 PM
turboeg77's Avatar
Default Re: (JDM-Civic-Hatch)
post some pics and update us when she hits the rollers
Old Apr 5, 2006 | 07:30 PM
JMac76913's Avatar
Default Re: another built D coming up (turboeg77)
good luck with the build... looks nice
Old Apr 5, 2006 | 09:19 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: another built D coming up (2nTeHPiNk)
What block/head/tranny?
Old Apr 6, 2006 | 07:52 AM
Laserjock's Avatar
Default Re: another built D coming up (boostincoupe)
who do you guys go to for head porting?
ballpark price
i'll hopefully get my Y8 head soooon or find a replacement
Old Apr 6, 2006 | 08:13 AM
EF9ZC's Avatar
I'm getting earl and portflow to do my head pm him pretty good prices
Old Apr 6, 2006 | 06:32 PM
JDMCRX's Avatar
Default Re: (EF9ZC)
Nice guy i hope this year to hit 300-340 whp on pump on the D series lol
Old Apr 13, 2006 | 07:55 AM
turboeg77's Avatar
Default Re: (JDMCRX)
headgames makes an awesome d series head. same as with the pink full-race hatch if i remeber correctly they revved it past 9000 without problems
Old Apr 13, 2006 | 07:57 AM
turboeg77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">What block/head/tranny? </TD></TR></TABLE>
its a y8 block,y8 head,y8 tranny
Old Apr 13, 2006 | 08:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboeg77 &raquo;</TD></TR><TR><TD CLASS="quote">
its a y8 block,y8 head,y8 tranny</TD></TR></TABLE>
How are you going to deal with the P2P timing issue? Do you already have a good map to start out with?
Old Apr 13, 2006 | 08:23 AM
gitwidit's Avatar
Lookin good!
Is that clutch net stage 2 an organic disc or puck?
Old Apr 14, 2006 | 06:44 AM
turboeg77's Avatar
How are you going to deal with the P2P timing issue? Do you already have a good map to start out with?</TD></TR></TABLE>
havent had timing issues. im running the map i was running last time before the build. just going to break her in and then tune.
gitwidit,
its the metalic disc. and i decided to use an exedy twin diaphram pressure plate
civicboy07
Oct 21, 2014 05:44 AM
egcivic92
Feb 9, 2009 11:04 AM
redlinetuning
Oct 17, 2008 08:13 AM
turbocivic0618
54
Apr 18, 2006 10:16 PM
