Am I missing anything from my build?
Old Jul 12, 2012 | 05:04 PM
butterbeer2fd's Avatar
Default Am I missing anything from my build?
So I'm at the point where I just want to plan out all the parts that I need to buy for my build, I just wanted to post this up to make sure I'm not missing any important parts to make this all fit into my car, I want EVERYTHING I need on this list, the only thing I want to exclude on this list are gaskets and anything less than $20 basically. So if you guys see anything obvious let me know! Alright here's my build, I own a 2000 Integra LS and this is for a LS/Vtec turbo build:
Block-
B18B1
9.1:1 JE Pistons
ACL Bearings
ARP Head studs
ARP Rod Bolts
Golden Eagle Vtec Conversion
Eagle Rods
Go-Autoworks Turbo Kit T3/T4 60 trim .63 A/R
Apexi WS2 80mm
Energy suspension motor mount/torque mount inserts
Precision 1000cc Injectors
Walboro 255 fuel pump
B18C Oil Pump (Optional)
B18C Water pump
B18C Timing Belt
Heads-
OEM Head Gasket
GSR Complete P72 Head
GSR Intake Manifold
Electronics-
Hondata S300 w/ Boost Solenoid
OBD2B to OBD1 Distributor Harness
OBD2B to OBD1 ECU Harness
4 Bar MAP Sensor
Drivetrain-
GSR Tranny
Competition stage 4 unsprung clutch
Resurfaced Flywheel
Old Jul 12, 2012 | 05:33 PM
TheShodan's Avatar
Moderator
Default Re: Am I missing anything from my build?
Stage 4 unsprung... EEEK.
Old Jul 12, 2012 | 05:46 PM
Khnemu's Avatar
I drive on the CC Stage 5 unsprung and it's very easy to drive. Not much slippage but it's not a pain for stop and go traffic.
Old Jul 12, 2012 | 05:59 PM
EF9_TryMe's Avatar
Stop and go Traffic is the worst dude.
Old Jul 12, 2012 | 06:02 PM
haha I'm still debating between the two
Old Jul 12, 2012 | 06:07 PM
Khnemu's Avatar
I'd rather it take more finesse to drive then to spit a spring and have to replace the clutch.
Just get used to the unsprung.
Old Jul 12, 2012 | 10:45 PM
yzracer323's Avatar
What kind of power are you looking for?
Id look into injector dynamics 1000cc injectors, and get a fuel pressure regulator. A wideband o2 sensor wouldnt be a bad idea either. Maybe a catch can setup.
Good luck
Old Jul 13, 2012 | 03:45 AM
oh yeah, forgot about wideband lol that's something I'll definitely get, I'm my goal is 400 whp but realistically idk if I can hit that until I build my heads lol, I'd be happy with 350+. from what I've read stock FPR should be ok with the power I'm aiming for, anyone have any input on this?
as for tuning in terms of gauges will I only need a wideband and boost gauge to tune? i'm really pushin my budget so I figure I could get oil pressure/fuel pressure later
Old Jul 13, 2012 | 10:35 AM
Ben Huynh's Avatar
I'd recommend adding a VTEC head to the mix. The LS head flows like a dog.
Old Jul 13, 2012 | 11:37 AM
ralph11sec's Avatar
^ i think he is using vtec head. gsr.
that setup sounds like somewhere in the 300range- 400 range.
Old Jul 13, 2012 | 11:58 AM
wantboost's Avatar
Who is Mr Robot?
lol Mac...
What he said, but I haven't driven on it yet... Can't be any worse than the twin plate in the z06.... Talk about hard, try modulating all that torque at low rpm in traffic. Its a bitch
Old Jul 13, 2012 | 12:03 PM
Ben Huynh's Avatar
Thanks just saw that. I'd also recommend a mount kit over the mount inserts and essential gauges. Btw, Eagle rods already come with ARP bolts.
Old Jul 13, 2012 | 12:54 PM
wantboost's Avatar
Who is Mr Robot?
Yea the inserts are pointless... like bandaids are to a stab wound.
Old Jul 13, 2012 | 01:03 PM
DC2Bobby's Avatar
I might have missed it from the list but do you have a wastegate and blow off valve already?
Old Jul 13, 2012 | 01:30 PM
wantboost's Avatar
Who is Mr Robot?
Since he said Turbo kit I would assume so
Old Jul 14, 2012 | 06:25 AM
oh okay, and yup turbo kit comes with bov manifold intercooler wastegate piping etc, should have everything for the turbo already. and yeah, I was going to use a GSR head, thanks for the tip about the eagle rods though...didn't realize they came with bolts already.
any reason the mount inserts are bad aside from vibrations?? i want to get hasport mounts but i'd rather spend the money on gauges to get a good tune and get the car running properly
lastly is my stock cooling system good? haven't really read much about aftermarket radiators except for that people get them cause they have fitment problems with the turbo..
and i think i've decided on a sprung clutch just cause from what i've read unsprung gives more shock to the tranny and this is more of a street car than a track car lol, i dont think id mind driving with the unsprung clutch tho, i'm just bummed out about the downside that it wear ur transmission parts more
Old Jul 14, 2012 | 12:58 PM
wantboost's Avatar
Who is Mr Robot?
you wont be able to run a full sized radiator.... so you'll need a half core
Agamemnon96
21
Oct 18, 2016 05:34 AM
SloHa+ch
Feb 18, 2012 03:55 PM
-Whitey-
13
Jun 29, 2006 10:57 PM
Novtecdohc
10
Jan 25, 2006 07:34 PM
InfamousRS
Dec 11, 2001 01:06 PM
