AFC Hack users!
Old Sep 3, 2002 | 06:15 AM
zojirushi's Avatar
Default AFC Hack users!
Any of you afc hack users having any problems? Seems my ecu keeps seeing boost even tho my settings are at most -30%
My cel keeps on coming on. DOH! any suggestions?
Old Sep 3, 2002 | 06:25 AM
genop's Avatar
Default Re: AFC Hack users! (zojirushi)
how much boost are you trying to push??
Old Sep 3, 2002 | 07:34 AM
98civicEX's Avatar
yes, -30 is too much, shouldn't go below -35%
Old Sep 3, 2002 | 09:35 AM
zojirushi's Avatar
Default Re: AFC Hack users! (98civicEX)
i'm only pushing .45 bar or 7 psi. i'm using 370 cc injectors. my idle fuel pressure is at 43 psi. It never did it before... just started...
Old Sep 3, 2002 | 10:25 AM
zojirushi's Avatar
help!!! i can't stand this stupid cel... everytime it goes on, the car goes into limp mode. driving around in limp mode sucks. the car seems to over heat really quickly.
Old Sep 3, 2002 | 11:44 AM
clm_Sol's Avatar
Well, everytime I've read about the S/V-AFC "hack" it's said to use a set of 440 or 450cc injectors, so that may be your problem. Read this page about it if you haven't already: http://www.thedropshop.tv/vafc.htm
HTH
Old Sep 3, 2002 | 12:37 PM
tyrant's Avatar
Default Re: AFC Hack users! (clm_Sol)
ive been getting the same problems lately, to temporarly fix my problem i ran one check valve to the map sensor and it runs alot better, so im getting another map sensor to see if that fully fixes my problem
Old Sep 3, 2002 | 12:48 PM
98civicEX's Avatar
you need bigger injectors, because -30% won't cut it, you can't run that rich, you need to be at no lower the -35% and then you won't throw a CEL. invest in some bigger injectors...once your run the car where you don't have to have to go below -35% then your set. 450cc or 440cc will do the trick. if you set the car w/ -35% right now, you won't throw a CEL, BUT you may be running to lean running w/ the 370cc's
Old Sep 3, 2002 | 02:40 PM
Smashback's Avatar
Yep, I tried with 310's at -30% and got a CEL everytime I went over like 5 PSI.
Old Sep 3, 2002 | 04:36 PM
liam821's Avatar
25 Year Member
yea get some bigger injectors... 450cc is what seems to work best with the afc hack.
liam
Old Sep 3, 2002 | 09:10 PM
wickedxboi's Avatar
Default Re: AFC Hack users! (liam821)
does anyone know if dsm 390cc injectors will work?
Old Sep 3, 2002 | 09:20 PM
rioninja's Avatar
You can drop the vafc down to -35%, and then increase your fuel pressure a bit to add a little fuel back. b
NeXtLeVeL_TyPe_R
Jul 26, 2003 11:58 PM
zojirushi
Dec 22, 2002 08:15 AM
filetofit
Sep 4, 2002 11:30 AM
asianspeed
Aug 22, 2002 09:12 PM
