AEM 5bar map with s300
Old Jun 11, 2007 | 08:09 PM
Boosteddb8's Avatar
Default AEM 5bar map with s300
The setting for the 5bar map sensor on the s300, are those the specs for the AEM 5bar map or a differnt sensor?
Looking to upgrade from my 3bar cuz it was maxxed out on the dyno.
Old Jun 11, 2007 | 08:51 PM
Boosteddb8's Avatar
Default Re: AEM 5bar map with s300 (Boosteddb8)
any info I want to order one tonight so I can go back to finish tunning
Old Jun 12, 2007 | 04:34 AM
boostedcivicsir's Avatar
Mr. Badwrench
how much boost? i will max out a 3 bar, but my turbo will probably top out at 3.5. thats what evans suggested to me for my setup. damn july 27 is coming fast.
Old Jun 12, 2007 | 06:12 AM
tony1's Avatar
Default Re: AEM 5bar map with s300 (boostedcivicsir)
Yes, the 5 bar settings in the s300 will work with the AEM sensor. I wouldn't bother with a 3.5 bar, if not now, at some point in the future it will be maxed out again. Just get the 5 bar and be done with it. Some will argue that you loose some resolution, but i don't believe that it makes a difference. You don't need a ton of resolution in the MAP rows, for the most part it's a simple double air double fuel calculation. I map my race car every 50kpa (7ish psi).
Old Jun 12, 2007 | 06:37 AM
Mr. Badwrench
Default Re: AEM 5bar map with s300 (tony1)
havent purchased yet tony, so i will talk to jeff and go from there. i thought the same with resolution, but you are correct in the future, with a t4 frame, i will probably exceed the 3.5, thats why i was asking about how much boost he was running. but it makes sense.
Old Jun 12, 2007 | 06:42 AM
Turbo-charged's Avatar
we have a car here right now with a 5 bar and a gt28 lol
Old Jun 12, 2007 | 11:30 AM
Boosteddb8's Avatar
Default Re: AEM 5bar map with s300 (Turbo-charged)
Right now im running 27psi but the turbo still had room to make more power, so we stop the tune till I get the bigger map, I would be close to maxing out a 3.5 also, that why I wanted to just go with the 5bar to have room to grow espicailly after I go with a bigger turbo later down the road.
Just want to make sure that the s300 can run with a AEM 5bar for sure so I can make the order. Any good place's to scoop one up from?
Old Jun 12, 2007 | 11:56 AM
iBrandon's Avatar
5 bar!
Old Jun 12, 2007 | 02:28 PM
allstokhonda's Avatar
subscribed.. Need a 5 bar too..
Old Jun 12, 2007 | 03:24 PM
sctuned.com's Avatar
Banned
Default Re: (allstokhonda)
Thats all we use on the S300 customers locally. 5 Bar AEM Part #30-2130-75
ludecz
Engine Management and Tuning
Jun 27, 2008 12:21 PM
turboeg77
Feb 26, 2006 04:18 PM
Derek14
Apr 28, 2004 09:18 AM
int3gra
Jul 4, 2003 11:49 AM
R THIS
Jun 12, 2003 04:01 PM
