Adjusting Boost Need Help
Old Apr 4, 2006 | 12:17 PM
JDMTRSPORTS's Avatar
Default Adjusting Boost Need Help
I have the Sohc Greddy turbo kit and i heard u could change the Boost on it from the Internal Wastegate anyone have Some pics on what this exactly looks like so i could Boost Higher
Thanks
Old Apr 4, 2006 | 12:39 PM
Soccerking3000's Avatar
Default Re: Adjusting Boost Need Help (JDMTRSPORTS)
if you look on teh actuator arm its threaded on the end that attachs to the flapper arm, just shorten the length of the arm and it should boost higher to a degree, its not the best way to go about things, just get a boost controller or make one for 5 dollars
Old Apr 4, 2006 | 01:09 PM
Default Re: Adjusting Boost Need Help (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">if you look on teh actuator arm its threaded on the end that attachs to the flapper arm, just shorten the length of the arm and it should boost higher to a degree, its not the best way to go about things, just get a boost controller or make one for 5 dollars</TD></TR></TABLE>
How do i make that one for $5
Old Apr 4, 2006 | 01:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTRSPORTS &raquo;</TD></TR><TR><TD CLASS="quote">How do i make that one for $5</TD></TR></TABLE>
not 5 but 12
http://www.geocities.com/chmwatson/FAQs/mbc.html
Old Apr 4, 2006 | 01:22 PM
Thanks but on that arm i make it long or short? also u would happen to have a pic? thanks
Old Apr 4, 2006 | 01:36 PM
you make it shorter here is a pic
it might not be the exact same thing but close enough
Old Apr 4, 2006 | 01:54 PM
[IMGhttp://i12.photobucket.com/albums/a237/jdmhatch18/b39bc001.jpg][/IMG]
so its not that 10M Bolt that i Boxed in Yellow?
Old Apr 4, 2006 | 01:55 PM
Old Apr 4, 2006 | 01:57 PM
yea you need to loosen that first the the bracket to thr right of it with the hole that attaches to the flapper will be able to spin, once you have shortened it take that nut and retighten it down
Old Apr 4, 2006 | 02:04 PM
cool whats the estimated boost on this do u know?
Old Apr 4, 2006 | 02:17 PM
it'll bring it up a few psi to 8-9
Old Apr 4, 2006 | 02:41 PM
Old Apr 4, 2006 | 02:59 PM
96 GSR-T's Avatar
I think I just saw a thread about how to blow your motor.
Old Apr 4, 2006 | 03:22 PM
Default Re: Adjusting Boost Need Help (96 GSR-T)
what are you talking about? if he is running a greddy kit and has an e-manage it is setup to run more thna the stock 5.5 psi just an fyi
Old Apr 4, 2006 | 03:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">I think I just saw a thread about how to blow your motor.</TD></TR></TABLE>
Uhh what thread?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">what are you talking about? if he is running a greddy kit and has an e-manage it is setup to run more thna the stock 5.5 psi just an fyi</TD></TR></TABLE>
Im hopefully going to be going Hondata
Old Apr 4, 2006 | 03:38 PM
well i dont think he had any idea wtf he was talking about
Old Apr 4, 2006 | 03:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">well i dont think he had any idea wtf he was talking about</TD></TR></TABLE>
hahaha
SloB16crxMike
Aug 15, 2006 10:31 AM
thruvines87
Dec 6, 2004 10:00 PM
Patron
Jul 23, 2004 07:02 AM
mogz
Jan 12, 2004 10:00 AM
B_1_8_hatch
Oct 6, 2003 12:01 AM
