Adjust the angle of the turbo inlets?! NoOb..
Old Jul 20, 2009 | 07:42 PM
jv88_dc2's Avatar
Default Adjust the angle of the turbo inlets?! NoOb..
Okay so i recently purchased a turbonetics t62-1 and i had a turbonetics t3 which came with the manifold im planning to use..now the problem is that this is how the t62-1 looks like
http://www.youngsautofab.com/shop/im...7777777777.jpg
..see how the angle of the inlet/outlet of the turbo is about 90 degrees?? And i want to adjust it so that the cold side is facing down when mounted on the manifold instead of facing towards the radiator like this..
http://www.streetkiaz.com/streetkiaz...otos/12544.jpg
Im a noob at this stuff and i was wondering if there is a way i can do it myself or if i would need to send it out to someone to do it for me??
thanks H-t
Old Jul 20, 2009 | 08:04 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
Default Re: Adjust the angle of the turbo inlets?! NoOb..
if im not mistaken you had be able to clock that turbo. loosen the 13mm bolts on the compressor housing and turn gently to the desired position and do the same for the exhaust side. but make sure the oil drain is facing down.
Old Jul 20, 2009 | 08:10 PM
jdm inc's Avatar
loosening the outermost bolt sets and turn the housings to where you need them.
Old Jul 20, 2009 | 08:38 PM
tek_civic's Avatar
Do some searching using the term clocking or clock turbo or similar. There are a lot of threads on this and if you turn it too much you can run into problems, but generally its fool proof.
Old Jul 21, 2009 | 12:15 AM
jdm inc's Avatar
here ya go
http://www.youtube.com/watch?v=amSFViIAWew
Old Jul 21, 2009 | 06:34 AM
project dc2's Avatar
very good ! vids easy for everyone
Old Jul 21, 2009 | 11:11 AM
jv88_dc2's Avatar
wow, alot easier than i thought..thanks guys!
radioren
Aug 13, 2005 07:38 AM
NumberB
Sep 11, 2004 12:37 AM
Integra_Boi
Jul 13, 2002 08:12 PM
ezark
Jun 13, 2002 11:09 PM
B18C-RnVA
May 5, 2002 05:30 PM
