Add on vacuum pump?
Old Jul 23, 2003 | 08:39 AM
Bnjmn's Avatar
Default Add on vacuum pump?
Anyone know of any cheap (like a stock ford/chevy item) vacuum pump that can be added onto a Honda engine for crankcase ventilation?
Thanks
Ben
Old Jul 23, 2003 | 08:49 AM
Greyout's Avatar
Default Re: Add on vacuum pump? (Bnjmn)
I am thinking of doing this as well. Initially I thought you had to tap the block right under the cylinders, but apparently you can use the stock PCV location?
Old Jul 23, 2003 | 08:58 AM
GraphiteAccord's Avatar
there are some race cars doing this, but on street cars i believe its yet to be done, which is funny, because its easy HP
Old Jul 23, 2003 | 09:11 AM
Bnjmn's Avatar
Default Re: Add on vacuum pump? (GraphiteAccord)
On car-part.com there is a choice of "vacuum pump" which means it came stock on something...mounting it might be a different story but I'm sure something could be worked out.
Old Jul 23, 2003 | 09:43 AM
asterix_2ksi's Avatar
New User
You can use exhaust flow to create a vacuum to suck out crank case pressures. Then you don't have to deal with the hp loss of a pump driven vacuum, amp needs of an electric one, weight of the pump, installation location and engine bay space. Search for the post where Earl or someone showed their setup... picture links probably don't work any more though since they didn't when I looked at them.
Old Jul 23, 2003 | 10:43 AM
93LSivic's Avatar
I know of this. You can find the needed part from a later model Oldsmobile sedan and I think some Caddy's.
DireFire34
11
Aug 1, 2006 12:26 PM
imadigitalgod
Jul 16, 2006 10:47 AM
speedminded
Aug 16, 2004 09:43 AM
b18cx
Jun 7, 2004 10:04 AM
DLB1994
Aug 28, 2002 06:53 PM
