any one make a vacuum pump system for hondas
like v8 guys have its a vacuum pump that pull all the unwanted crankcase pressure out the crankcase to free up more hp and theres lots of other good thing about it
very good for a turbo car becouse they dont pull vacuum under load
Re: any one make a vacuum pump system for hondas (DLB1994)
someting like that would most definitely be custom, but if and when you'd decide to do sometihng like this, you'd have to source a motor to generate the vacuum, and also know what a desirable vacuum reading would be. If you run something and its a little off, who knows if you'll be fine or if something catastrophic is going to happen..
Summit sells vacuum pumps but they are very expensive. I thought about getting one but just can't justify the cost...
I like your Idea I have been thinking about this myself. I guess you could get a cheap one (not for automotive use) but I am not sure if it would pull enough volume of air to creat a vacum. I know some older GM cars had vacum pumps not sure what they where for but they are quiet loud.
Re: any one make a vacuum pump system for hondas (89civic1.8T)
Do it old school and just get a inline one way valve running from the block and head and lead into the exhaust line. The flow of the exhaust will create a natural vacum and the one way valve will let the exhaust pull, but cant let it go back in.
Re: any one make a vacuum pump system for hondas (top notch)
