vafc settings,please explain.
Old Aug 23, 2003 | 08:26 PM
civictypenos's Avatar
Default vafc settings,please explain.
what does the "th-point" setting need to be set at,or what exactly does it change.for example,if "lo" is at 10%,what does that mean,and if "hi" is at 50%,what does that mean and how do they correspond with each other??
thanx alot for any help here.im thinking that if "lo" is set at 10%,then your "narr.thr" setting are being used at 10% of your throttle??
and if your "hi" is set at 50% then thats when the "wide.thr" setting kick in,is this right?
Old Aug 23, 2003 | 10:36 PM
nevin's Avatar
it explains this in the manual. http://www.apexi.com
Old Aug 24, 2003 | 08:06 AM
Default Re: (nevin)
it does not explain it in the manual,i looked.it explains how to set it but it does not explain why you should set it or for what reason to set it.
Old Aug 25, 2003 | 04:37 AM
Default Re: (civictypenos)
someone,please?
QuestRacingType-R
Nov 23, 2001 06:16 PM
