97 GST - BOV problems, help. (candyoffvalve)
Old Aug 3, 2003 | 11:22 AM
Boltz's Avatar
Default 97 GST - BOV problems, help. (candyoffvalve)
my friend got a stock 97 gst last week and a few days ago i installed a turboxs rfl bov and an injen intake. everything was running fine for 3 days then last night my friend calls me saying that his car is fuc#ed so i tell him to drive it over and meet me at my house.
so anyways he calls me back saying he is stuck on the way over. so i get dropped off to where his car is and drive it home no problems? once i pull in my driveway i give it a little gas in neutral to make it blow off and let go and when the cars RPM's are lowering it shoots down and dies. so i look under his engine bay to make sure that everything is still exactly how i left it when the install was completed and everything was fine..... here is the problem
after inspecting everything i realize that there is some red goo that dried on the outside of the blowoff valve and i say "that looks like candy" my friend laughs at me. so i lick my finger and run it over the red spot and taste it.. guess what..its SUGAR? so then i uninstalled everything and dissassembled the blowoff valve completely and cannot find any trace of where that came from...
so then i ask my friend when he opened his hood last and he tells me he hasnt opened it since i did the installs? anyone ever hear of anything like this ever? no we werent eating redhots or drinking fruit punch during the install .
anyways once the car was put back to stock the problem that it had with dying in neutral after a little punch of the throttle was over?
cliffnotes - Why would the eclipse die in neutral after punching the gas?
- why was there candy in the blowoff valve?
Old Aug 3, 2003 | 11:24 AM
Boltz's Avatar
Default Re: 97 GST - BOV problems, help. (Civic420)
yes folks, candy, in the blowoff valve
Old Aug 3, 2003 | 11:28 AM
ffgeon's Avatar
Why would the eclipse die in neutral after punching the gas? because it is a mitsubishi, duh. jk dude. ya i dont have an answer for either question. were vaccume lines hooked up correctly? did a coupler come loose in ic piping?
Old Aug 3, 2003 | 11:29 AM
lazerus's Avatar
that's one fucked up problem....
You may have to tighen up your BOV, because it may be letting air in at idle.
on a DSM this will cause significant problems, because the air for idle is not being metered. This is why stock BOV is re-routed back to the intake (keep metered air in the intake)
If it dies like it did (revving it and hearing the bov etc.) what happens is the engine goes rich, because you let out already metered air that it thinks it injested, so it meteres more air.. and you can see the problem.
This is one reason why on first gens if you try and vent the stock bov to atmosphere, you pretty much have to crush it to work well without dying out on you (lets air in at idle) but in his case with the aftermarket spring you can just tighten it..
As far as the candy.... someone had to have dropped candy in the charge pipe, or in the BOV. that simple.
Cliffnotes: 2gdsm bov recirculates, aftermarket releases metered air = goes rich after BOV Vent.
heh
So you licked its bov and it tasted good, huh?? hahaha
Old Aug 3, 2003 | 11:49 AM
Dsm634's Avatar
LOUD NOISES
Thats what is weird though, absolutely no candy or food was around the car at all, and no one has even seen under the hood except justin who installed it. And yes, the candy did taste good
Old Aug 3, 2003 | 11:53 AM
Boltz's Avatar
Default Re: 97 GST - BOV problems, help. (lazerus)
thanks for the help lazerus. no it didnt taste good but i could tell it was sweet. it was weird because it looked like it dried like a sticky goo and was very hard...... i thought that it would make it rich also because it wouldnt be rerouted into the intake, but when he bought it at the store the guy told him it wouldnt be a problem.
so i see 2 possible ways of fixing the problem;
1) put more discs in the blowoff valve to tighten the spring
2) exchange rfl for a r34 bov and reroute it into the intake?
what do you think
Old Aug 3, 2003 | 01:58 PM
baphomet's Avatar
where did you buy the blow off valve? Maybe one of the packing people was eating some candy and drooled inside - when it heated up the now hardened candy laced drool melted and oozed out.
Its really funny, but I'm sure it wouldn't be if it happened to me - goodluck!
My new sig
"Why would the eclipse die in neutral after punching the gas?
- why was there candy in the blowoff valve?"
Modified by b3435 at 9:27 PM 8/4/2003
Old Aug 3, 2003 | 05:01 PM
Full-Race Javier's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">
my old turbo nissan (MAF) ran like sh#t when i vented my bov (1st gen DSM) to atmosphere. the AF was around 9.0-10.0:1 at idle...if it idled. and drivability in between shifts was always entertaining
Old Aug 3, 2003 | 06:45 PM
Bailhatch's Avatar
Default Re: 97 GST - BOV problems, help. (javierb14)
locktite tastes sweet and comes in a translucent red ...and ya, venting to atmosphere is not a great setup but the sound is mad stunna so most people deal with it.
Old Aug 4, 2003 | 10:39 AM
Boltz's Avatar
Default Re: 97 GST - BOV problems, help. (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">locktite tastes sweet and comes in a translucent red ...and ya, venting to atmosphere is not a great setup but the sound is mad stunna so most people deal with it. </TD></TR></TABLE>
WTF is locktite?the eclipse isnt my car so i dunno what you mean by stunna
Old Aug 5, 2003 | 07:38 AM
Bailhatch's Avatar
it is used to keep bolts and nuts from loosening.
Old Aug 5, 2003 | 09:02 AM
Boltz's Avatar
well now i know its locktite
thanks
Old Aug 5, 2003 | 10:10 AM
lazerus's Avatar
how many times did you taste it?
Old Aug 5, 2003 | 10:45 AM
psileepR's Avatar
New User
listen to javier and lazerus.
Eclispes use the MAF compared to our hondas using MAP's.
Gas mileage goes to hell if u dont recirculate the bov because the ecu see's air going into the engine.... it "disapears" cuz its vented to the atmosphere so the extra gas going into the engine for that air is wasted...
recirculate the one ur friend has or get one that you can recirculate or prepare to open your friends wallet for gas money.
Old Aug 5, 2003 | 05:03 PM
Boltz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">how many times did you taste it? </TD></TR></TABLE>
i only had a few spoonfuls... ..jeez
psileepeR - yea i figured it would run a lot better with the recirculated BOV, but the problem is already solved, traded the turboxs rfl for a turboxs type-r34 so we can recirculate.
Old Aug 7, 2003 | 07:25 PM
Bailhatch's Avatar
Default Re: 97 GST - BOV problems, help. (BoostRotter)
I wouldn't recommend drinking more than a cup of red locktite. unless you chase it with some copper anti seize on toast.
Old Aug 10, 2003 | 08:30 AM
Boltz's Avatar
dont worry i chased it with liver of sulfur
Turbo D17
Dec 12, 2004 12:06 PM
Blanket Jackson
Nov 28, 2004 12:18 PM
Duck Sauce
Sep 21, 2004 07:37 PM
FMXer
Oct 9, 2002 09:26 AM
Jkan2001
Oct 3, 2002 05:26 AM
