95gsr turbo
Old Jun 21, 2005 | 07:55 PM
95turbogsr's Avatar
Default 95gsr turbo
I just bought a to4e 70 trim for my gsr im looking for any info you guys may have as to parts that are worth buying and will do me good
Old Jun 21, 2005 | 08:01 PM
Juggernaut 2's Avatar
Default Re: 95gsr turbo (95turbogsr)
Is the turbo the only thing you have? If so what are you trying to produce your question is to broad.
Old Jun 21, 2005 | 08:08 PM
95turbogsr's Avatar
Default Re: 95gsr turbo (Juggernaut 2)
Sorry im looking for 300 - 400 i got an intercooler as well flows 1020 cfm im looking for the manifold and downpipe as well im going to order some pistons and rods that are forged and 9:1 comp rebuild the heald with tit retainers dual springs stainless valves full 3 inch exhuast high flow cat but im lost as how much boost i can push wat size injectors to use just some of the tech stuff im work on cars for a living but this turbo is my first event out and i know im going to need a new comp my friend recommed a hondata instead of chipped ecu so im just looking for some guidance from you experianced guys out there.
Old Jun 21, 2005 | 08:28 PM
all go teg's Avatar
if your looking on what injectors to use, here is a link to RC injectors and there worksheet to calculate injector sizes. its a bit on the confusing side but give it a try
hope this helps [http://www.rceng.com/technical.htm#WORKSHEET]
92hatcheg6
Jan 31, 2011 08:38 PM
suthernbred904
Oct 14, 2009 07:21 AM
screaminvtec
Nov 22, 2006 11:16 AM
Yemesio
Jun 20, 2006 08:27 AM
Btothe3rdDegree
Mar 9, 2004 05:11 PM
