91 Integra Hondata ???
Old Mar 16, 2004 | 06:51 PM
91SIR's Avatar
Default 91 Integra Hondata ???
I have a 0bd0 pr4 ecu, hondata dosnt make a system for the ecu (G2 guys know what i mean) Question is can i get a pr3 ecu have stage 2b put on it and have it set up run my ls motor(non vtec) or will i have to convert to 0bd1 and run a p28? any help would be great
Old Mar 16, 2004 | 07:21 PM
dategb16vortech's Avatar
Default Re: 91 Integra Hondata ??? (91SIR)
i think hondata makes a stage 1 2 or 3 system for obdo cars otherwise your best bet would be to upgrade to obd1 as it will give you more power anyway and you can run a 4 wire heated o2 sensor instead of those 2 dumb o2 sensors in the exhaust manifold much easier for running turbo or supercharger. I have a 93 integra gs that i swapped in a fully built b16 and fabricated my setup to accept the vortech blower currently running a p28 with hondata
Old Mar 17, 2004 | 01:27 PM
91SIR's Avatar
Default Re: 91 Integra Hondata ??? (dategb16vortech)
wheres all the boosted DAs at ? Main thing is will this pr3 vtec ecu run my
non vtec motor if i have the stage 2b installed on it?
Old Mar 17, 2004 | 04:53 PM
xenocron's Avatar
Check out http://www.turboedit.org for OBD0
If you must go to Hondata, buy a Harness on here (see sponsor forum) get an OBD1 distro and a P28 ECU
Old Mar 22, 2004 | 08:49 PM
91SIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SIR &raquo;</TD></TR><TR><TD CLASS="quote"> Main thing is will this pr3 vtec ecu run my
non vtec motor if i have the stage 2b installed on it?</TD></TR></TABLE>
yes or no??????
Old Mar 22, 2004 | 08:53 PM
DENCIO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SIR &raquo;</TD></TR><TR><TD CLASS="quote">I have a 0bd0 pr4 ecu, hondata dosnt make a system for the ecu (G2 guys know what i mean) Question is can i get a pr3 ecu have stage 2b put on it and have it set up run my ls motor(non vtec) or will i have to convert to 0bd1 and run a p28? any help would be great
I'd like to know too....I am boostin my 91 teg soon...
Old Mar 22, 2004 | 09:14 PM
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SIR &raquo;</TD></TR><TR><TD CLASS="quote">I have a 0bd0 pr4 ecu, hondata dosnt make a system for the ecu (G2 guys know what i mean) Question is can i get a pr3 ecu have stage 2b put on it and have it set up run my ls motor(non vtec) or will i have to convert to 0bd1 and run a p28? any help would be great </TD></TR></TABLE>
to run Hondata on an OBD0 LS easiest way is to convert to OBD1 using a conversion harness, an OBD1 LS distributor and an OBD1 LS P75 or 92+ PR4 ECU(why would you need a P28 to run an LS??)
but the easiest and most practical way to do this ALTOGETHER would be to listen to Xenocron and go with Turboedit much less hassle...
Old Mar 23, 2004 | 04:19 AM
xenocron's Avatar
Default Re: 91 Integra Hondata ??? (DA-MAX)
Thanks DA-MAX.
Oh yeah, for got to mention TurboEdit is FREE!
acura95integra
Feb 10, 2008 01:12 PM
crampinyourstyle
Aug 17, 2006 10:41 AM
havok hybrid
Feb 13, 2003 03:17 PM
RTW DC2R
May 22, 2002 07:59 AM
sgT
Aug 16, 2001 09:46 PM
