85mm too big for boost?
Old Oct 9, 2005 | 08:15 PM
sheepey's Avatar
Default 85mm too big for boost?
This year I have been building a NA b16. I have everything done and all the parts. A good friend of mine has a 500 whp turbo car , and wow i fell in love. Now ive gone soo far with this all motor build and have be thinkin about going to turbo, i would of course change the pistons out and do some things differnet but my worries are the bore, too big?
Old Oct 9, 2005 | 08:33 PM
Soccerking3000's Avatar
Default Re: 85mm too big for boost? (sheepey)
is it sleeved? if so you can never go to big lol.
Old Oct 9, 2005 | 08:47 PM
sheepey's Avatar
yes of course. Eagle sleeves
Old Oct 9, 2005 | 10:09 PM
Default Re: (sheepey)
that might be pushing it a little, most bores are gunna be around 84mm, since the cylinder pressures are of course more with boost. How much power you looking to get, since they are full iron sleeves they should hold a great deal...
Old Oct 9, 2005 | 10:57 PM
Adi Radoncic's Avatar
On Fire!
Default Re: (Soccerking3000)
I ran my b16 at 85mm for a while and it held up good made 470whp for a while on it. Id say run it, you got nothin to worry about.
Old Oct 10, 2005 | 12:41 AM
909ER's Avatar
IT can work, the main concern is the Sealing of the head gasket.
You have to keep in mind that with 85mm bore, the cylinders are getting close to super thin and with boost, the high cylinder pressures make the this situation more prone to blowing head gaskets.
Old Oct 10, 2005 | 03:06 AM
M.A.R.C.'s Avatar
also, god forbid something goes wrong, and you have to bore it over... ur kinda screwed. then it'd be really thin.
Old Oct 10, 2005 | 07:54 AM
cubish's Avatar
Default Re: 85mm too big for boost? (M.A.R.C.)
gsc is running a 85mm block. car makes 700+hp and runs 9.60's@155
Old Oct 10, 2005 | 07:56 AM
boostjunkie757's Avatar
Default Re: 85mm too big for boost? (909ER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 909ER &raquo;</TD></TR><TR><TD CLASS="quote">IT can work, the main concern is the Sealing of the head gasket.
but blowing the head gasket will save the block..
Old Oct 10, 2005 | 08:37 AM
86si's Avatar
Default Re: 85mm too big for boost? (boostjunkie757)
85mm here. i would have went 84.5mm but the cyl were badly damaged and had no choice. no problems yet.
Old Oct 10, 2005 | 03:58 PM
joelsgirlisfatandugly's Avatar
Default Re: 85mm too big for boost? (86si)
the man is correct sealing the headgasket is the problem. I was going to to the same but golden eagle talked me out of it!
Coolero
23
Dec 10, 2009 02:55 PM
b17integra
Sep 29, 2005 09:56 AM
LSEGHATCH
Mar 14, 2005 05:28 PM
Fuzion
Sep 11, 2003 01:49 PM
2ltrsnailpwr
Jun 23, 2003 02:06 PM
