8 injector manifold?
Old Jun 30, 2002 | 08:36 PM
[B16]HiGhCaM's Avatar
Default 8 injector manifold?
Has anyone herd on the release date on Eldebrocks manifold for the B16 with 8 injectors. Would like to here if anyone else is using a 8 injector set up?
Old Jun 30, 2002 | 08:49 PM
PrecisionH23a's Avatar
Default Re: 8 injector manifold? ([B16]HiGhCaM)
Ive heard a good amount on the 8 injector set up. Some of the guys that are pushing out 400+hp are running this setup use 4 stock injectors and fuel rail then have 4 more larger injectors with another fuel rail tapped into the manifold that only spray when the engine is under boost. One benifit this has for daily drivers is it lets you retain stock idle quite easily. There is a shop out in texas that is running this setup on their gsr, its putting down 430hp to the wheels, its a daily driver also. If you are intersted in speaking to the shop send me and IM and ill give you their number.
Old Jun 30, 2002 | 08:53 PM
Default Re: 8 injector manifold? (GudeH23a)
Thanks for the replay. I got everything else mapped out rather well just waiting for eldebrocks manifold to be released. Thats the reason why I am going to use this injection set up. I plan on using AEMs ems to control everthing. Thx
non-VTEC
Mar 13, 2010 09:55 AM
ciscoscivic
Welding / Fabrication
Dec 30, 2007 07:31 PM
ImportMotorSpec
Feb 23, 2007 08:43 AM
Xemu
Nov 14, 2006 10:30 AM
xtal
Sep 17, 2003 03:46 PM
