8-10 psi Safc tuning?
Hello everyone i was intersted in finding out,if u all (from those of u with Safc's) found that tuning with the Safc is a sufficient enough device for tunning an 8-10 psi b series motor....
if not what is needed to makeing sure an 8-10 psi motor runs good enough to not blow...?
Re: 8-10 psi Safc tuning? (greekspeed)
Yes you can but I think your going to need some bigger injectors. What disc are you running in your FMU? Have you done a fuel pump, inline or intank?
Re: 8-10 psi Safc tuning? (autoEXturbo)
i believe my fmu is a 12:1 (its a jackson FMU), and i plan on installing the jackon fuel pump and prolly 310c-370cc injectors along with the Safc....
so what do u think? will that be good enough then?
now the safc doesnt have any way to read the air/fuel ratio correct? so how would i go about getting air/fuel ratio readings so i can tune it? from what i understand the autometer air/fuel gauges dont work for ****....
I actually use the greddy egt gauge. But if you do that, put it on a dyno so you can see where you egt's match up with the a/f so when you tune it on the street or when you don't have a dyno at hand you can know where your car starts to run really lean.
Re: 8-10 psi Safc tuning? (turbosol)
well honestly i cant say.... that is what a firend told me JR fmu's are.... it was never relavent for me to know untill now when i want to add more boost...
u may very well be right...
jackhunt321
09-06-2005 04:32 PM
