Comparing two fuel setups....Need Input
Old Feb 24, 2003 | 12:59 PM
Teg4e's Avatar
Default Comparing two fuel setups....Need Input
I'm debating the following fuel setups, both involving the S-AFC.
*Apex'i S-AFC, 310cc injectors, Vortec FMU w/ 8:1 disk, inline fuel pump
-or-
*Apex'i S-AFC "hack", 450cc dsm injectors, resistor box, inline fuel pump.
What are the pros and cons of each setup? thanks.
Old Feb 24, 2003 | 01:12 PM
DeepSi's Avatar
Default Re: Comparing two fuel setups....Need Input (Teg4e)
More tunable and adjustable. Might want to get an intank fuel instead.
fuel is dependent on the FMU. not really tunable. What are you going to use the S-AFC for?
Old Feb 24, 2003 | 04:29 PM
Teg4e's Avatar
bump
Old Feb 24, 2003 | 04:36 PM
b16 matt's Avatar
I have a vortec fmu for sale
Old Feb 24, 2003 | 04:40 PM
Teg4e's Avatar
Default Re: Comparing two fuel setups....Need Input (b16matt)
i own the vortec fmu, with 12:1 disk already
Old Feb 25, 2003 | 06:17 AM
Xscream's Avatar
As much as everyone knocks the SAFC/FMU setup I personally like it a lot. You don't have the surging issues that you do have with the AFC Hack. As long as you set your AFC up properly on a dyno it will run IMO just as good as any hack w/o the daily drivability issues.
Old Feb 25, 2003 | 10:16 AM
Teg4e's Avatar
Default Re: Comparing two fuel setups....Need Input (Xscream)
So, you're saying the afc + fmu is more driveable than the afc hack? anyone have opinions on this?
Old Feb 25, 2003 | 11:29 AM
Blaze45's Avatar
Brrraaaap!
Your fuel delivery for you car is not something that you want to go the cheap route when it comes to FI. I would suggest a SMC w/ 450cc injectors and some dyno tunning.
Good Luck
Blaze
Old Feb 25, 2003 | 05:09 PM
Teg4e's Avatar
Default Re: Comparing two fuel setups....Need Input (Blaze45)
isn't this a contradiction? the smc's cheaper than the s-afc. besides, i think the two setups would cost about the same.
Old Feb 26, 2003 | 06:05 AM
Xscream's Avatar
Well the AFC has more tuning options then a SMC so thats a plus. The AFC/FMU combo does run very rich untill you dyno it and get the daily driving proporties setup but after that its awesome IMO. The AFC hack I have found is harder to get the partial throttle setup right w.o surging.. This is just what I have found personally - there are a lot of other things I have heard about good and bad for all three setups.
Old Feb 26, 2003 | 06:22 AM
ekb18c's Avatar
You don't want to go cheap on your fuel setup so go Hondata.
Old Feb 26, 2003 | 06:35 AM
Muckman's Avatar
Moderator in Chief
Default Re: Comparing two fuel setups....Need Input (ekb18c)
What would you suggest for a new turbo user who is learning about tuning and so forth? Would a hondata/EMS setup be too complicated ot start off with or should the novice (me) start off with a piggy back fuel controller and standard boost contoller?
Old Feb 26, 2003 | 07:03 AM
BDTURBO's Avatar
Default Re: Comparing two fuel setups....Need Input (Muckman)
do u like the GTECH?
Old Feb 26, 2003 | 09:02 AM
Xscream's Avatar
Hondata is the best way to go but the AFC is a hell of a lot easier route to start with.
Old Feb 26, 2003 | 09:34 AM
autoEXturbo's Avatar
3 out of 4 friends that run the hack have their car out of comission due to fuel problems, i say that's a little problem with the hack over the afc/fmu setup.
I like the fmu setup, it's what i run. Vortech 12:1, 255 intank, 440's, missing link, safc. 10psi=326hp and 221ft lbs to the wheels on pump gas. Been driving it for over 7months and 10kmiles and haven't had a problem yet.
Old Feb 26, 2003 | 11:57 AM
Teg4e's Avatar
Default Re: Comparing two fuel setups....Need Input (autoEXturbo)
don't you run insanely rich on that setup? 12:1 and 440's?
Old Feb 26, 2003 | 12:01 PM
right now i am but that's due to tunning. That will be worked out shortly.
Old Feb 26, 2003 | 02:17 PM
b16 matt's Avatar
I went fmu and vafc, it sucked. Now I go HOndata and love it.
Old Feb 26, 2003 | 03:56 PM
Muckman's Avatar
Moderator in Chief
Why does it suck?
BDTURBO - I like my gtech alot. Havent used it in months tho. I ran it when I went to the track once, it was less than one hundreth of a second off my time slip. It calculates trap speed differently tho.
Old Feb 26, 2003 | 05:27 PM
b16 matt's Avatar
because it caused my car to buck, and know I run 16psi with full internals.
Old Feb 27, 2003 | 03:33 PM
Teg4e's Avatar
Default Re: Comparing two fuel setups....Need Input (DeepSi)
why isn't this setup tunable? why can't i use the s-afc to fine tune?
Old Feb 28, 2003 | 04:45 AM
i'd like to know the same, considering my car was dyno tuned using a safc. I run a 12:1 fmu, 440's, safc, 255lph intank and missing link. You can tune using the safc on a car running an fmu.
Old Feb 28, 2003 | 12:52 PM
Teg4e's Avatar
bump
jackhunt321
Sep 6, 2005 04:32 PM
EJ8 GSR-T
Aug 23, 2005 07:49 PM
DXturbo
Jul 1, 2003 08:28 PM
soundman
Apr 25, 2003 12:03 PM
TurbothisLS
Sep 22, 2002 07:22 AM
