620whp
Old Apr 15, 2004 | 03:56 PM
hybrid901's Avatar
Default 620whp
Here is the latest dyno of my street car. The graph looks funky because I have to start on low boost and switch to high boost in the middle of the run. The tires still spun on the dyno but not nearly as bad as just running on high boost. This was done with about 20 miles on the new motor and eagle rods. My manley rods were damaged when my oil pump broke.
26psi c116
B18c1
CP 10:1 84.5mm
Eagle Gsr Rods
Golden Eagle Sleeves
Balanced Gsr Crank
ACL Bearing
Polk Performance CNC Head w valve train
JG Intake Manifold
JG Throttle Body
ITR Cams 0,0
small 1.5" log manifold
3" Downpipe
Hondata s200
Precision 1000cc
Precision 750HP Intercooler
2.5" Piping
PT67 T4 .68
Tial 40mm 19psi
Cryoed ACT Xtreme
Croyed ACT Ultralight Flywheel
Cryoed Oil Pump
Fluiddamper Crank Pulley
Gsr Tranny cryoed
Quaife LSD cryoed
TCI Axles
SX Fuel System
-10/-6 Lines (fast-turbo.com)
If I think of anything else I will add it later.
Modified by hybrid901 at 1:27 AM 4/16/2004
Old Apr 15, 2004 | 03:59 PM
FOrSfEd's Avatar
Default Re: 620whp (hybrid901)
Damn those are some hella nice numbers, can you post your set up again. I say again cause I know you have posted before.
Old Apr 15, 2004 | 04:04 PM
DENCIO's Avatar
Default Re: 620whp (FOrSfEd)
very sick#s
Old Apr 15, 2004 | 04:08 PM
Rod.'s Avatar
Default Re: 620whp (hookonboost)
I bet you have to do a rolling race in 4th gear. I bet you still spin with that power. The numbers are sick though
Old Apr 15, 2004 | 04:10 PM
99B16Si's Avatar
Default Re: 620whp (redturbocivic)
jesus duff!!!
Old Apr 15, 2004 | 04:15 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: 620whp (99B16Si)
niiiiccceeeee
Old Apr 15, 2004 | 04:17 PM
alpha's Avatar
Old Apr 15, 2004 | 04:25 PM
adhana2's Avatar
hey josh very nice numbers, man i wanna see how far u gonna push it
Old Apr 15, 2004 | 04:28 PM
hybrid901's Avatar
Default Re: 620whp (adhana2)
I will probably do the rest of the tuning at the track. I can get it not to spin on the dyno anymore. Any ideas.
Old Apr 15, 2004 | 04:36 PM
Hoosier Daddy's Avatar
Sweet ****
Old Apr 15, 2004 | 04:38 PM
TurboTegB18c's Avatar
Good Lord! Very Nice #'s.
Old Apr 15, 2004 | 04:40 PM
TrueNorthStar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">I will probably do the rest of the tuning at the track. I can get it not to spin on the dyno anymore. Any ideas. </TD></TR></TABLE>
Find someone with a dynapack dyno. At least it bolts up to your hubs.
Old Apr 15, 2004 | 04:43 PM
hybrid901's Avatar
Default Re: 620whp (TrueNorthStar)
I have a dynojet here at the shop and don't know of another dyno anywhere close.
Old Apr 15, 2004 | 05:00 PM
AVATAR's Avatar
Guess I'll be the first to ask . . . 5/16 or 3/8 rod bolts?
Old Apr 15, 2004 | 05:08 PM
Cramerox's Avatar
question- what do you think the highest boost you can run on pump gas with your compression? nice setup man
Old Apr 15, 2004 | 05:23 PM
95LSDOHC's Avatar
Default Re: 620whp (Cramerox)
siiiiiiick
Old Apr 15, 2004 | 05:27 PM
Boostfed's Avatar
New User
Nice #s Josh, glad to see this set up working out for you now. I hope to redyno at the end of the month once my new fuel pump gets here. Good luck at the track, over 600whp is ALOT to control.
Old Apr 15, 2004 | 05:34 PM
racinskittle's Avatar
Default Re: (Boostfed)
DAMN, nice numbers!!! That's badass. Can't wait to see what she'll run
Old Apr 15, 2004 | 05:41 PM
Cyber ITR's Avatar
Default Re: 620whp (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">Guess I'll be the first to ask . . . 5/16 or 3/8 rod bolts?</TD></TR></TABLE>
Old Apr 15, 2004 | 05:44 PM
psileepR's Avatar
New User
very nice numbers. Is cryoing all the stuff worth it in your opinion? im thinking about doing it to my setup. I know you have only driven your car a little bit after this new setup.
Old Apr 15, 2004 | 05:47 PM
Hispeed's Avatar
Not the safest thing to do .. but since you asked have to big people stand on the front core support. I don't know how your dyno is set up but the one around here is aerial and you can put a steel bar underneth the braces and when you tie the car down from the tow hooks you go under the bar and then to the brace. It pulls the car down when you tighten the straps. Another thing I do is I use a set of throw down 22" slicks. I feel your frustrations Oh and btw.. great numbers! Will you be in baton rouge?
Old Apr 15, 2004 | 05:50 PM
fernancivic's Avatar
No Sales Forums
great #'s
Old Apr 15, 2004 | 05:52 PM
Kelly.'s Avatar
I've quit using this account
Default Re: 620whp (CFT-Si)
Old Apr 15, 2004 | 06:22 PM
JDogg's Avatar
Default Re: 620whp (llewsirc)
nice numbers......
tire spin you say..... thats why we have a dynapack.. takes the tires out of the equation
Old Apr 15, 2004 | 06:46 PM
RobbieG35's Avatar
12 Years Strong
Default Re: 620whp (JDogg)
my God! Josh, your car is a beast, good luck not spinning with all that power
