620whp
Here is the latest dyno of my street car. The graph looks funky because I have to start on low boost and switch to high boost in the middle of the run. The tires still spun on the dyno but not nearly as bad as just running on high boost. This was done with about 20 miles on the new motor and eagle rods. My manley rods were damaged when my oil pump broke.
26psi c116 http://www.imagestation.com/picture/...d/f92ee375.jpg B18c1 CP 10:1 84.5mm Eagle Gsr Rods Golden Eagle Sleeves Balanced Gsr Crank ACL Bearing Polk Performance CNC Head w valve train JG Intake Manifold JG Throttle Body ITR Cams 0,0 small 1.5" log manifold 3" Downpipe Hondata s200 Precision 1000cc Precision 750HP Intercooler 2.5" Piping PT67 T4 .68 Tial 40mm 19psi Cryoed ACT Xtreme Croyed ACT Ultralight Flywheel Cryoed Oil Pump Fluiddamper Crank Pulley Gsr Tranny cryoed Quaife LSD cryoed TCI Axles SX Fuel System -10/-6 Lines (fast-turbo.com) If I think of anything else I will add it later. Modified by hybrid901 at 1:27 AM 4/16/2004 |
Re: 620whp (hybrid901)
Damn those are some hella nice numbers, can you post your set up again. I say again cause I know you have posted before.
Re: 620whp (FOrSfEd)
Re: 620whp (hookonboost)
I bet you have to do a rolling race in 4th gear. I bet you still spin with that power. The numbers are sick though
Re: 620whp (redturbocivic)
Re: 620whp (99B16Si)
niiiiccceeeee https://honda-tech.com/forums/images/smilies/emthup.gif
hey josh very nice numbers, man i wanna see how far u gonna push it https://honda-tech.com/forums/images/smilies/emthup.gif
Re: 620whp (adhana2)
I will probably do the rest of the tuning at the track. I can get it not to spin on the dyno anymore. Any ideas.
Good Lord! Very Nice #'s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 »</TD></TR><TR><TD CLASS="quote">I will probably do the rest of the tuning at the track. I can get it not to spin on the dyno anymore. Any ideas. </TD></TR></TABLE>
Find someone with a dynapack dyno. At least it bolts up to your hubs. |
Re: 620whp (TrueNorthStar)
I have a dynojet here at the shop and don't know of another dyno anywhere close.
Guess I'll be the first to ask . . . 5/16 or 3/8 rod bolts?
question- what do you think the highest boost you can run on pump gas with your compression? nice setup man https://honda-tech.com/forums/images/smilies/emthup.gif
Re: 620whp (Cramerox)
Nice #s Josh, glad to see this set up working out for you now. I hope to redyno at the end of the month once my new fuel pump gets here. https://honda-tech.com/forums/images...es/emsmile.gif Good luck at the track, over 600whp is ALOT to control. https://honda-tech.com/forums/images/smilies/emwink.gif
Re: (Boostfed)
DAMN, nice numbers!!! That's badass. Can't wait to see what she'll run https://honda-tech.com/forums/images...es/emsmile.gif
Re: 620whp (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR »</TD></TR><TR><TD CLASS="quote">Guess I'll be the first to ask . . . 5/16 or 3/8 rod bolts?</TD></TR></TABLE>
very nice numbers. Is cryoing all the stuff worth it in your opinion? im thinking about doing it to my setup. I know you have only driven your car a little bit after this new setup.
Not the safest thing to do .. but since you asked have to big people stand on the front core support. I don't know how your dyno is set up but the one around here is aerial and you can put a steel bar underneth the braces and when you tie the car down from the tow hooks you go under the bar and then to the brace. It pulls the car down when you tighten the straps. Another thing I do is I use a set of throw down 22" slicks. I feel your frustrations https://honda-tech.com/forums/images/smilies/emwink.gif Oh and btw.. great numbers! Will you be in baton rouge?
Re: 620whp (CFT-Si)
Re: 620whp (llewsirc)
nice numbers......
tire spin you say..... thats why we have a dynapack.. takes the tires out of the equation https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: 620whp (JDogg)
https://honda-tech.com/forums/images...s/emsmileo.gif my God! Josh, your car is a beast, good luck not spinning with all that power
