5year down time, prep to run again?
Old Jul 7, 2009 | 02:42 PM
Honda4life777's Avatar
Default 5year down time, prep to run again?
My sol has been on bricks for 5 years waiting for a new throwout bearing. I am putting a turbo on now too. After sitting for 5 years what all do I need to do before I start it up with a turbo? It was in sound running condition except for the throwout bearing. All I can think of is fresh coolant, oil change and a few gallons of fresh 93+ petro. Or should I get some gas,oil and coolant treatment additives or seafoam? (putting in new fuel pump and injectors)
Old Jul 7, 2009 | 02:50 PM
Garage 808 Hatch's Avatar
Default Re: 5year down time, prep to run again?
It took you 5 years to get a throwout bearing?? WTF
Old Jul 7, 2009 | 02:59 PM
b20beast83's Avatar
probably made it himself
Old Jul 7, 2009 | 03:17 PM
It was my dads del and he has a few hondas and he just never got around to puttin the bearing in. I got tired of seeing that potential on bricks and talked him into selling it to me. But I still need to know if there is anything I should do before starting it up after a 5 year nap and adding a turbo.
Old Jul 7, 2009 | 03:23 PM
komat's Avatar
new oil and prime it to it makes pressure
check belts for cracks
i would put a can of octane booster if theres gas in it
Old Jul 7, 2009 | 03:52 PM
raceACCORDingly's Avatar
is there a lot of 5yr old gas in the tank?
Old Jul 7, 2009 | 03:56 PM
I am replacing all the belts. The gas tank is half full. So I should add octane booster and maybe few gallons of fresh gas?? How do i prime oil?
Old Jul 7, 2009 | 04:47 PM
komat's Avatar
drain the gas and put fresh gas or fill it up with the old with octane booster
take the ecu fuse out from the engine bay and crank it for 10sec then let then starter rest and crank it again
Old Jul 7, 2009 | 05:05 PM
912's Avatar
912
drain gas and change fuel filter forsure, throw old gas away start fresh, wouldnt hurt to take valve cover off and pour oil all over valve train, change oil after you get it running
balbowskie
Jun 17, 2015 04:15 PM
4drEF
Feb 21, 2009 06:51 PM
blwn95civic
Oct 12, 2008 02:41 AM
mike93eh2
Sep 17, 2006 08:28 AM
aberkrombie
Jul 20, 2004 11:41 PM
